Compatible Mobile GPS units
UPMan
In Memoriam
Arlington, TX
I use a mag-mount puck on my trunk lid. Works greate, and I can easily remove it for car washes or long term parking...
UPMan
In Memoriam
Arlington, TX
Lots of similar items on the web. However, there is nothing that will convert to allow a USB device (like a USB GPS) to operate on a computer that has only an RS232 port.
K4APR
Chesapeake, VA.
to davidmc36: I found a USB to Serial adaptor for the GPS
USB to Serial RS232 DB9 9 Pin Adapter for GPS Garmin 9p - eBay (item 320314832981 end time Apr-27-09 19:42:07 PDT)
I think I will give it a try.
This will NOT work! Don't waste your money. Devices like this one are meant to TAKE IN SERIAL and OUTPUT TO A USB port of a computer. Not the other way around. When this adapter is properly installed with the appropriate driver, a virtual com port is emulated on the OS ie. COM 10. You then point your software running to this virtual com port. This is usless for a device looking for a straight serial stream, such as the 996.
K4APR
Chesapeake, VA.
I am sure i missed it simply because of my own ineptitude and lack of hardware savvy, but am I gonna be pretty much limited to a Puck-like unit or piggybacking from a conventional handheld GPS unit? Ideally what i would like to do is just drill the hole and make a more permanent installation on my trunk versus velcro-ing something to the deck behind my back seats. Not to get all wacker-esque or anything, but i would prefer an installation that resembles what one would see on a public safety vehicle... Or am i just confusing hardware bits? Again, my apologies if this has already been covered or if it is completely off-base...
There is no reason for you to drill any holes. Any decent puck GPS will work just fine on either the dash or rear deck of a car. I have a Garmin 18 LVC in my car and it just lays on the back deck. Zero problems. Even the lower end Deluo style GPS receivers work well this way.
davidmc36
South East Ontario
As UpMan pointed out that will not allow you to connect a USB GPS device to the serial port on your scanner. It would be kinda like trying to push a rope up a hill:D. You don't have a mummy and a daddy there, it's more like two daddies:twisted:. They should almost be more correctly called a Serial to USB adapter. In other words, you can't get there from here.
I would still be interested in checking out whether the USB interface for the Pharos puck that came with Streets and trips is in the cable or in the puck. The puck has ten or fifteen pins where the cable plugs in and the other end is obvioulsly a USB plug. Could you hack up a serial cable straight from the puck?
Columbia Co. OR
My "puck" is just stuck to the inside of the windshield with two sided foam tape. Upper right corner, out of sight(sort of) out of mind. I have the Garmin GPS 18 and the biggest comlaint that I have with it is the size of hole that would be needed to route the wires better, wish I could unplug the puck.
h8tdigitalradio
Uniden Beta Tester
Six Feet Over
Another option is a Garmin Nuvi 350 using the newly developed converter cable that translates the Garmin Binary format to and from NMEA data at 4800 baud. The maker is Argent Data Systems and the cable was originally made for Amateur Radio APRS applications, but I can't see why it would not work in this application as well.
Are you saying this cable will work with the 996 and a Garmin nuvi 300 series GPS? I ask because I use 2 GPS devices (eTrex Legend and nuvi 360) and this cable would eliminate the need to use the eTrex.
TIA
73
Dave AKA The Tripzter
mrscanner2008
Canada
what puck model of GPS do you recommend for the 996T?
thanks
Mrscanner2008
UPMan
In Memoriam
Arlington, TX
In theory, most GPS receivers have NMEA serial output available somewhere in their guts (because AFAIK, all the major chipsets output NMEA). However, finding it, buffering to it, and getting it out to a usable connector...
bob1857
GPS for the 996
I have been using the Garmin 18 serial version for two years now. I have it mounted on the corner of the dash and it works great. I have never had a problem with it and it is a great additon to 996, much better than locking out systems manually. I think its the only way to travel. In fact I just picked up a BC15 and I am gonna use the same GPS for that one as well.
Bob
davidmc36
South East Ontario
UPMan
In Memoriam
Arlington, TX
Expensive solution ($99 for the board, $49 for the antenna...)
K4APR
Chesapeake, VA.
Maybe I should just install one of these inside the 996:D
GPS Central (Canada) 'Garmin GPS 15L & GPS 15H' Page
What kind of space is inside of the 996? Looks like I need to get working on an internal GPS module. I already have several GPS modules designed into several of my products:
http://www.rpc-electronics.com/rtrakpromo.php
With a little bit of time, I can produce a simple GPS module that outputs 4800 baud RS232 serial data. Knowing the size of the module and the minimal extras to make it work, I know I can make it slim enough to put inside the scanner.
K4APR
Chesapeake, VA.
In theory, most GPS receivers have NMEA serial output available somewhere in their guts...
This is true. Usually, its at a TTL level, either 5V or 3.3V. Luckily, it's not hard to "convert" this to RS232 voltages +/-12VDC. That is why I am thinking it makes sense to just design one from the ground up since I already have 90% of the circuit designed for another product of mine.
davidmc36
South East Ontario
For sure not the most economical way to go, and not for the faint of heart either. Not as bad as it looks though, those are CAD and I got an antenna off Ebay for 15CAD.
More like........why climb Mt. Everest..........Because I can:twisted::twisted:
K4APR
Chesapeake, VA.
Iv'e had mine open. There's enough to put ten or fifteen of those little matchbook size modules that I linked to.
The module you linked to is a great one, but huge compared to the chipset I am referring to. The chipset I work with is about 10mm x 10mm.
