Connecticut users and Firmware For SDS 100
dispatcher812
Connecticut
Has anyone in CT with an SDS 100 updated to the new firmware? If so what are your thoughts? After looking through the Uniden forum not sure weather I should upgrade or wait.
CentracomGold
Here
I updated the firmware & I actually noticed a slight improvement on analog conventional channels sounding a bit stronger but more or less everything else runs the same
tmeyer101
Yes, I think it is worth it.
Agree -
Also, FWIW, just got my SDS100 back from Uniden Repair (broken USB mini port and CSJ issue) - Delivered on 1/12, sent back on the 17th. Not only does it work great, cant believe the quick turnaround!
Rt169Radio
CT
I personally will not update yet, waiting to see results from other people using the update.
darkness975
Latrodectus
I am with you on this update. I think I will wait another few weeks if not a month
Me too. I feel no rush to jump in.
As with computers, phones, etc I am wary of updates that could cause issues. It's happened before with other devices.
Ct_Pirate
Just revived the need for communication equipment
Orange, Ct
I usually wait for the second release, just after the first round of bugs are worked out.
AF1UD
I've noticed my SDS200 has a hard time locking on to P25P2 transmissions that are mid transmission. It's about 50-50 if it will actually lock on and play audio.
This is off 1 tower with an indoor antenna. RX is usually full scale.
dispatcher812
Connecticut
Thanks guys. I see that Uniden had released several updates after my original post. Maybe they got all the bugs out. Still skeptical on updating though. is there a way to pull the current firm ware version out of the scanner before upgrading just in case I need to change it back?
pro92b
Mutated Member
Current firmware should be stored on your computer. My computer has it archived at C:\ProgramData\Uniden\BCDx36HP_Sentinel\Updater. Before you do anything else copy the firmware file and add it to a different folder so you still have it when Sentinel overwrites the stored firmware file in the Updater folder.
dispatcher812
Connecticut
I have everything up to C:\ProgramData\Uniden\BCDx36HP_Sentinel\. Nothing that says updater. I even searched for it.
pro92b
Mutated Member
OK, what firmware version do you need to archive?
