So I've seen people do both. Enter in every frequency and only enter in the control channels. My local trunked system is a Harris system where in theory everything can be a control channel so I put everything in. However I am traveling around again for work and my local state system (CSERN/CLMRN) is much bigger. Would only programming the control channels help or hurt me? I could see it helping by improving the scanning times but hurting becuase its not looking at every frequency.
Thoughts? What do you do? I know my Unication Pager only needs control channels.
The subscriber radios only use the control channels (Harris and Explicit systems excluded), and the scanner operates the same way.
Years ago I had a trunked system that shared a control channel with another that was pretty close. I could never control which was being scanned. That is why I never program voice-only channels (except as noted above). I don't need another system that may use those voice channels as their control channels hijacking my scanning. This may bot be an issue in more rural areas.
These days, I even have a statewide system that uses sites that can be heard in the same area that use the same control channel. Which site you receive depends on the location or direction of your antenna.
This is one reason I pushed for NAC support. Now I know I am scanning only the site I want to be scanning. But I still never program frequencies that will not be used as control channels. The odds of one of those frequencies being re-assigned as a control channel is lower than the odds a completely new frequency will be added.
