Copiah County Railroad
tvengr
Well Known Member
Baltimore County, MD
Which frequencies are used for the rail line through Hazlehurst and Crystal Springs in Copiah County? Every source I have checked shows a different answer. Thanks!
slhbeard
Vicksburg, Ms
I would suggest going to copiah county on radioreference. Under statewide, you will see amtrack, and whatever railroad that goes thru there. I know it's not Kansas City and Canadian Nstional. So, it may be CSX or someone else. I know this probably doesn't help much.
slhbeard
Vicksburg, Ms
Correction on my previous post. The Railroad that goes thru Copiah County is Canadian National and Amtrack.
INDY72
Indianapolis, IN
CN/IC McComb Sub! You can also pick up the Jackson ops, and Meridian Speedway from CS. (CPKC) For CN/IC 160.9200, 161.1900. For CPKC 161.5650, 160.5450
Amtrak CONO uses the CN/IC. Have fun in my old stomping grounds. An great rail fan spot also is at Copiah-Lincoln Community College down in Wesson, as well as the park downtown CS! The closest yard is Brookhaven. Of course in Brookhaven, you can catch the interchange from Natchez.
INDY72
Indianapolis, IN
One of my best friends sometimes comes to CS to get train vids, its an perfect spot. Used to suck, but they fixed up the area.
