Copying between codeplugs
DarcyB
I have several 5061 radios I need to update programming for, I have a number of channels that need to be copied between multiple radios. Is there a way to copy and paste between code plugs ? When I try and open a second instance of CS-F3160/F5060 it does not let me and says that a copy is already running. I know I can open one file then copy 1 channel, then open the other code plug and paste the one channel, save, close open.... but that is quite a bit of labour for the 30 ish channels I need to do this with across a dozen radios...
Any Hints??
12dbsinad
Just highlight all the channels, save, open new codeplug and past. No need to just do individual channels.
New Zealand
Also make sure you are not changing from PMR to LMR or PMR to LMR as the copy paste function will not work.
The other way to do it is make one file then change the radios number / ID's and save as that ID
