Corning Fire Department
Disp46
Can someone in the Steuben County/City of Corning area update the RR Database info or confirm the current info listed is correct? From monitoring the Corning FD online feed it appears the dispatch channel is simplex and that the FD uses a P25 repeater for on scene operations. The FCC license makes it seem as though 453.8125 is the main dispatch frequency off a hill top base station while 460.4375 is the operations repeater (with P25 emissions designator) from a location within the city. PL and NAC codes would be appreciated.
k2hz
Rochester, NY
I have reached out many times for updates to the Steuben and Corning listings with little success. The last valid submission I received was from you on 2/14/2024. Since then, the only submission I received proved to be totally bogus and had to be deleted. Possibly you have some official contacts in the area you could confirm your information with.
Disp46
Thanks for all you do in keeping the RR databases updated. I will attempt to verify the FD info when I am in the area later next month. Was just hoping someone locally could help clarify before my trip.
k2hz
Rochester, NY
I have asked some reliable submitters who visit the area occasionally to check some things for me but their efforts have often been thwarted due to lack of activity during their brief stay. Good luck on your visit next month.
DaveNF2G
Latham, NY
Next time I visit family out that way (I have a grandniece due soon) I will see if I can pick up anything.
