correct GP360/380 software/cable?
JMR3865
Monmouth County, NJ
I have used the GP300 series CPS on the GP380 but cannot get it to work on the GP360. Does anyone know if that software will work on the GP360 and if the HT1250 cable will work with the GP?
Thanks, I don't normally deal with the GP series.
OFD-14-109
Otsego, MI USA
The HT1250 cable should work for the GP360, not sure on the software, as I have never used that software, what problem are you having programming it? Do you get an error on read/write?
yt1pro
Cable is the same, but you should use gp300/gm300 series cps
Sent from my Redmi Note 3 using Tapatalk
yt1pro
I know, but that's the name of the software...
Old Radius GP300 series are using DOS software.
bjornepappa
I also use the GP300 cps on my GP380, it works fine. It should also work great with the GP360, as it basically is the same radio without full keypad.
Your problem MAY be that the 360 has a newer firmware. New CPS works with old firmware, but old CPS don't work with new firmware.
What kind of error do you get?
Sent fra min SM-G930F via Tapatalk
