CPS Data Conversion
w6vny
I have a mix of new HP682, HP782, HP602 and HM782. I put togeher a base file for the HP782, attempting to clone it to the other radios returns "Model settings do not match". I attempted to use the CPS Data Conversion tool by reading a factory default radio & saving the file. Open Data Conversion, select the populated base file as source, file i just saved as dest and click convert. A few seconds later popup with Conversion Fail.
All radios have the same FW and radio data version. Ran CPS as admin. Can't think of anything I may be missing.
Any ideas?
alphaprime
You cannot clone different model radios. Each model radio must have a unique file. The conversion tool is for upgrading an older firmware radio file to the current firmware version in order to clone a newer radio from an older file, again same model radio.
w6vny
Thank you. I thought Upgrade CPS Data would be for firmware mismatches.
So there is no way to convert settings between models? That seems a bit shortsighted.
alphaprime
The only option of sharing channels or talkgroups between radio files is the Export feature. It's far from perfect, but it can be useful.
