CPS Error Message
cifd64
Northern Passaic County, NJ
After updating software and attempting to prog a CDM-1250, I get two error messages after trying to open a cpg.
1) CgToDb: Unable to set value returned by transform unpackList_Index1ForCP255 in slot 4239 of object Conventional Personality Proto_8821
2) PassII- Unable to transfer block Conventional Personality from CpDb to Db.
Please help.
Skypilot007
Medford, NJ
Did these errors happen while attempting to open a code plug or attempting to write a code plug to the radio? Please clairify.
What version of CPS are you using and what cables are you using? I know you said you upgraded your software but some folks don't upgrade thru motorola, just wanted to see if you have a somewhat current version of CPS. I've never seen those particular errors and I've programmed a lot of these radios.
cifd64
No, i go through businessonline.motorola. I have an account there. I was trying to open the cpg that i had worked on this morning, starting from a previous cpg. I am using R06.11.07. The original cpg was written with 6.10.
cifd64
And i can open the log without a prob. If i paste the log here, would something stand out?
  • DOHMHUHFCDM1250-03102010.pdf
Skypilot007
Medford, NJ
Can you open other saved codeplugs?
If you have a saved codeplug for the radio I would use it, make another copy and start over with the changes you were making. Or read the radio, save that codeplug and go from there. Something got hosed along the way somewhere. Usually CPS is good at telling you when you messed up.
cifd64
no issues opening other cpgs from this radio. CPS typically doesnt let you save if fields are invalid or something doesnt match up right. Sucks, 5 and a half hours rebuilding down the drain.
