Hello,
I own several Hytera PD782's and a couple of PD701's(all are OOB Hacked in previous versions of CPS) ... I recently upgraded one of the 702's to V 9 firmware and installed the new V9.02 NA CPS on my programming laptop. It seems the new CPS has now "encrypted" the radio ID information which returns "string not found" when searching for the radio's 01BD identifier (from the codeplug) when searching for it in the CPS config file for r92.zip/model.dat file.... the CPS rejects the modified model.dat file after it's been modded to change the bandsplits from 450,520 to 420,520... even if the time/date/CRC are reset to the same as the original unedited file was before unzipping and editing.... anyone find a workaround for this? Or will I have to try to downgrade the firmware back to v8 which had no problems accepting the OOB hack???
Can HEX editor viewing the active program in computer memory be used to mod the .exe to allow the frequency I need to enter to add a new digital channel to existing codeplug outside the radio's bandsplit?
Any input is appreciated.
