Croton Falls FD
Rescue20
New York
Hi,
I'm looking for the Croton Falls FD Districtwide in Westchester County frequency and PL. I have looked everywhere and can't find it.
Thank You in Advance!
jrock71984
croton falls repeater
rx453.16250 tx458.16250 346 DPL
Rescue20
New York
That's to repeat 60 control not their Districtwide. Thank you anyway!
scandude43
Danbury ct
That new uhf freq says it is their district wide but it is currently a cross and repeater as far as I can tell. And the DPL is 346
Btw the newer scanners on the market as well as the cheaper hts have dcs/pl search options
Rescue20
New York
Yeah thanks scandude43 I know they are using that as repeater I'm trying to find the districtwide channel I keep hearing CFFD units say on Fire 13 switch to districtwide.
scandude43
Danbury ct
I think there is only 1 UHF freq which, is currently being used as a crossband to 46.26 which in my opinion is a waste since there are a bunch of crossbands that service that area well
scandude43
Danbury ct
A better usage I think would to add a fire 13 UHF link, Somers has a vhf link since they use VHF but they are not the only dept to use fire 13. Croton falls FD, and Goldens Bridge FD, ETC so I think If Croton Falls has the resources and use UHF they could set up a uhf link, ( why use 2 radios ) right?
Rescue20
New York
Yup there are so many crossbands for 46.2600. I think the districtwide is VHF but I'm not sure. Yes if they made a UHF 46.2600 repeater they should make a FIRE 13 repeater.
Rescue20
New York
The above channel is the Croton Falls FD Districtwide as well as 46.26 Repeater.
scandude43
Danbury ct
4626 links
There seems to be a little confusion here regarding cross band repeaters and one directional links. In Westchester we have both being used. Westchester FDs early on were mostly using Low Band Frequencies such as 46.26,46.14,33.96mhz etc. in the 90s some departments began rebroadcasting low band traffic on UHF or VHF hence making a cross band repeater. You can transmit on a lets say the repeater pair is 453.56250 rx and 458.56250 tx. Transmitting on the input would be broadcasted on the low band freq. and vise versa. Now When Westchester County got licensed for their UHF TRS system,and hard pushed the agencies into using either an EMS or FD talk group, this gave Westchester The authority to regulate who and what is broadcasted over their system. Hence the Link, a link is usually a one direction receive only to a specific Talk Group. because you need a Specific ID to transmit on the highly regulated Talk Groups ,and the correct programming matrix, it is highly unlikely you will see a Bidirectional Link or a Cross band Repeater on the TRS system. Another note. The cross bands were put up to gain better reception for the pagers that only had an internal antenna, The TRS system has Better Coverage than the previous low band conventional system which, Almost every FD in Westchester had its own license for. That being said,There is a limited need for Repeaters. UHF has better penetration than the old low band system does anyway.
Btw, Thank God its not digital yet.
my two cents
