CTCSS Vs. DCS
RKG
Boston, MA
Can a transmitter or in this case a repeater transmit both ctcss and dcs be transmitted at the same time? In this case what I'm trying to achieve is using the dcs as an identifier being decoded and used to display what repeater was being used while the ctcss tone is used to open the squelch on the receivers.
I think the point is moot, since I am aware of no subscriber equipment or infrastructure station that will simultaneously transmit both a PL and a DPL.
That said, if such equipment existed I think you'd still have a problem. At a minimum, DPL is a bit stream at approximately 131 Hz, so that would certainly clash with an PL around 131.8, as well as harmonics.
