Cullman Al VHF P25 on Sdr
Bamapik
What is a free good SDR software available for listening to Cullman county P25? Thanks everyone in advance.
millam
Old Radio Guy
Look at this software, a lot of people use this along with Trunking Recorder I believe. I use DSDPlus
Fastlane, 10 bucks a year, 25 lifetime I believe. UniTrunker does P25, its free. To me SDRTrunk is the
less complicated to run, fill in the blanks kinda. UniTrunker, you need to provide a lot of info, same
with DSDPlus Fastlane.
Mil
dkcorlfla
Orlando
I don't recall Unitrunker needing much info to get going but it's not very intuitive. After it's setup it works great and has excellent logging. Let it run for a few days on a p25 system and it will log most of the talk groups and the hits for each. This info can then be used to program a p25 scanner.
Enforcer52
Lake Livingston, TX
From looking at the frequencies used in Cullman county, depending on what you want to listen to, you would need up to 3 sdrs to cover the 151-159 mhz range of the p25 systems that is used in the county, since a regular rtl-sdr only covers a 2.4mhz range at a time. To cover all the P25 & NBFM channels, probably 4 sdrs.
I also recommend SDRTrunk.
dkcorlfla
Orlando
Just one Airspy R2 could be used instead for a simpler setup. They do cost a lot more but have a much lower noise and from what I have seen with the one I'm using it works really well on a busy P25 system.
Bamapik
Thanks everyone! I think of trying SDRTrunk to see what happens.
