Curious about a good source for "antique" CB walkie talkie information
DaveC1964
Schaumburg, Il
I use an RCA to SO239 adapter in my handheld regularly. It comes in handy when I initially check the SWR on a large antenna before it goes up in the air. My old Radio Shack handheld is awesome. It's become my base station in a soft case many times, with the external antenna adapter and the 5 pin DIN microphone jack.
What Radio Shack WT do you have?
KEWB-N1EXA
Acushnet Heights Radio 740
Yes I do have the RCA jack. What I was wondering is if I connect the WT to the meter with an adapter like you show, would I then raise the built in antenna too or does an external antenna/load (which I don't have) need to be connected to the meter?
Don't Deploy the antenna ! keep it down..
To get your power reading you can purchase or make a 50 Ohm load..I wouldn't use 1 resistor you should use multiples in series or Parallel
as long as you get 50 ohms..You could google this on the web to get an idea.
You could feed an antenna as long as its got a good SWR reading to get a max power reading.
Peter N1EXA
DaveC1964
Schaumburg, Il
Peter N1EXA
So would any antenna attached to the meter work? Theoretically some short cheap mobile antenna would be good enough for that purpose right? If an antenna didn't have good SWR does that mean the power rating measurement is not accurate?
Also what would happen if the built in antenna was extended while connected to the meter?
oldcb
mantua, ohio
Thought I'd revive this thread....just wondering how you made out with your handhelds?.....I recently picked up two TRC-216's, I keep one as a mobil unit, and now use the other in place of where I had a much larger CB that I used as a base right by my PC, the 216 is so small it really isn't in the way like my other radio was, I made my own 1/4 wave antenna several years ago which still works great, I used the SO239 adapter to connect it up, I don't talk much with it, just mostly listen, if I decide to talk I'll used the hand mic from one of my many RS car CB's I own, living right next to interstate 80, there's still plenty of truckers chatting on these old CB's.
