polkaroo
Missed him again!
- Joined
- Apr 14, 2002
- Messages
- 429
- Reaction score
- 109
More of a UI annoyance, if someone else can verify or try to duplicate this behaviour? If the system screen zoom level is set to 100% and the Current Seen windows are quite large, if the computer switches the display to 125%+ and the window goes (partially) off-screen, the next time launching DSDPlus you won't be able to call up the window again, it'll just flash on the screen. I've seen some other apps, if they encounter this problem the window is automatically resized to fit the screen at the system display zoom level. This might be because how DSDPlus draws the windows isn't standard - scroll bars and window resizing only with the triangle (can't drag the window borders?)
The way to fix this is change the zoom level back to 100%, resize the offending window and move it closer to the upper left portion, then re-zoom the screen back to the larger size.
Display @ 100% on external desktop screen
Display @ 125% when external screen disconnected (since it's only a 15" screen and you know, old eyes...)
