Hey there, I'm new here. Long time scanner user, ham, etc. but I've been away for a while. I recently moved to the D/FW area of Texas, and it seems that most everything here is P25 phase 2. I have a Pro106 and other analog scanners, but most aren't very useful. So I'm looking to upgrade. I'm most interested in police, DPS (troopers), fire, and medical public service. No interest in DMR. So I think just P25 is all I need. I'm looking for something that can go nicely in the car if I wanted, although I'm also sort of interested in the SDS100 for portability. So looking for suggestions. SDS200? I also like the ability of the 596 to do streaming but I understand the SDS200 can do LAN streaming so I think that would be fine...thanks much.
Welcome to RadioReference and the DFW Metro area.
While it is true that most of the newer systems in the area are capable of P25 Phase II operation, not all are using Phase II exclusively. If you are in Tarrant County, or the 'Mid-Cities' area (Hurst, Euless, Bedford), one system you will likely monitor is
FWRRS. If you look at the system in the database, it is tagged as being a Phase II system. However, if you look at the talkgroups being used, you'll see that, for now, most of them are using Phase I, not Phase II. That's indicated by the
D in the mode column. Fort Worth proper, as well as Tarrant County, and the smaller suburbs, are still P25 Phase I. Arlington, Grand Prairie, and Irving, however, are using Phase II. Phase II talkgroups are identified with a
T in the mode column,
The new
Denton County system is using Phase II. as is
GMRS, the new system used by Garland, Mesquite, Rowlett, and Sachse.
PAWN, used by Plano and several neighboring cities, is Phase II capable, but most activity, for now, is Phase I. However, it's been noted that Plano will be shifting their talkgroups to Phase II exclusively in stages. Dallas (both city and county) is building a new P25 Phase II system to replace their mostly conventional public safety radio systems. The new system is projected to go online late next year.
While the only public safety user at this time is Highland Park, if you have an interest in EMS, note that CareFlite, a major air medical provider, uses a DMR
system. There are also four smaller Dallas County suburbs that use NXDN systems.
So, yes, you should look toward buying a P25 Phase II capable scanner. Besides the systems currently using that format, or are under construction, I would expect that many of those currently using P25 Phase I will transition to Phase II. The SDS series is a good choice, and for me, work well in areas with
simulcast distortion. Depending on your exact location, and your system(s) of interest, that could be a deciding factor. Your Pro-106 would work on the systems and talkgroups that are currently Phase I, however, there are some simulcast issues with some ofe systems. Check the threads down in the Texas forum for more comments along that line.
