Dang Ford..Could use some help on my antenna....
There's a number of ways to do the next step. A small set of needle nose pliers works well to hold the center section to keep it from turning.
Then put a wrench on the outer ring and snug it down. Do not over tighten it, but snug it down.
This is a small VHF antenna, but when you are done, this is what it'll look like:
slowmover
Fort Worth
niceguy71
Massachusetts
I purchased the mount and antenna that @mmckenna had recommend all ready. It should be here next week. I have actually had a CB in my my Ram 3500 before I picked up my new F-350. It was a cheap Uniden Pro505XL but it worked for what I needed it for. A very long time ago I was in CB pretty darn heavy. Back then it was much different then now. Everyone had one and we enjoyed talking on both base and mobile. 1965 I got my first Midland CB base station with a set of 4 element beam and rotor. We had a good time back then. Now 60 years later I still enjoy them. I started more research after not being able to get the radio in my f-350 to work correctly. That lead me to look for a smaller radio and new antenna. The ram had a K-40 mag mount that worked well. I decided to go ahead an drill a hole in my new truck. After thinking about it, it wouldn't be the first hole drilled in it. The factory put the first couple holes in it for GPS and what ever. So what's another one. I wished I would have waited on everything after finding this site, but it is what it is now!
AWESOME that your going to drill the hole.... I always hope a new guy in the hobby will buy something that works well like that K-40 you had.... and then slowly try to get the guys to upgrade..... you're jumping in feet first, good for you! I wish everyone would!
billdean
Michigan
I have found someone to install my NMO 27 antenna not to far away. Pro Comm a company that said they could do it. They will come to my house and install it here. They charge $160.00 per hour and said it would take 2 hours and that includes travel time. I believe I will let them do it as I don't really have the tools and knowledge of all the trim piece and air bags in my f350. I also ordered and new AT5555N-II to try to install into my truck too. I travel a lot and my up coming yearly trip to SW Arizona and back is a 60 hour ordeal. I want a good radio and antenna, installed right for that commute. I even ordered a Driver Extreme DRX9010 External Speaker. Where's it all going to go? Well I don't know, but will hopefully figure it out. If I don't then maybe I will have a Base Station in my 5th wheel in the desert.
Chris155
Southern Maryland
Industrial strength adhesive backed Velcro holds my 5555n2 on top of the dash. Not really anywhere else to mount it with good visibility from the driver seat. Truth is the radio works so well it’s worth velcroing on top of the dash. The smaller radios I’ve run mount easier but just don’t work as well.
slowmover
Fort Worth
Radio & Speaker Mount Solution.
LIDO MOUNT L-MAX DELUXE for Radio (seat bolt). Optional brace takes weight capacity to 17# from 8#
LIDO Headrest External Speaker Mount (DRX-901). Mount to outside of seat (window). I’d add a brace. (See pic below for stronger)
Magnetic Mic holder
My earlier links have been deleted.
Start points
Correct location for a speaker is over left shoulder (@jcrmadden DIY from steel
slowmover
Fort Worth
Thanks @slowmover. That helps a lot. I had been reviewing cup holder mounts, but I like this stuff better.
You’re welcome.
I’d get optional brace for radio mount “just because”. You may add something to it someday.
The speaker mount will need, IMO, some extra bracing. The 901 is heavy compared to other offerings (more cheaply made).
You’re about to have one helluva system. By which I mean the ease of use paired to gear quality (and install) will make speaking with others seamless.
That Ford will be an ambassador for a HQ “High Performance” Citizen Band Radio Rig.
Overcoming the deficiencies of the other mens radio rigs is the goal. “To Hear, and Be Heard”.
These days it’s about Clarity, not excess watts.
With the 5’er hitched you’ll not have such great TX/RX to the rear. Close couple and TTL Height is a barrier. My experience in big truck in such is that not a great deal of info is lost.
My trailer is lower, much farther away and my antenna is taller. I’ll be able to speak to someone passing a bit farther, is all.
Please test for 12V noise.
slowmover
Fort Worth
If you substantially up-size the DC GROUND from trailer to truck and install an RF Bond to jump the hitch plate these will improve performance.
Little things that add up.
LED lights, USB chargers, etc can add unwanted noise. Consider that testing as being part of the break-in period (driver settling into expectations).
Most noise comes in across the coax.
Almost got blanked by a passing pickup yesterday. Why I’ve persevered re S/NR
Post in thread 'Antenna Feedpoint Coax Choke'
Posts 51 & 52
billdean
Michigan
My 5th wheel is 13.5 feet to the top of the air conditioners. Hard to get over that. I was thinking of putting on the NMO30 with the W640 whip while traveling with it and then switch it out after get camped. Testing for 12V noise is just a matter of disconnecting the coax from the radio, right.
slowmover
Fort Worth
No reason to swap unless you love drive-thru. My permanent antenna is at 13’. (7’ tall). Testing my 60” backup lost several miles of range against the 84” (on road towards Interstate). That loss means fewer choices about re-routing myself in a timely fashion.
A retailer I’ve used often. May need a little, but mainly need to know to how isolate & ID.
billdean
Michigan
Will that work? I run a 1/4" plastic plate on my hitch instead of lube. Would that not isolate the trailer from the truck?
slowmover
Fort Worth
We need them on a common ground to greatest extent. The 7/way does it partially (trailer lights).
The RF Bond think of it (not accurate) as common voltage potential.
See K0BG on these.
(Edited post 51 above at end).
slowmover
Fort Worth
You may not need it.
The other test is a less than 3% Voltage Drop when the mic is keyed. 1/2V max. 13.8 to 13.3v, engine running with RPM high enough to have alternator kicked in).
This electrical strain reduction is why going to BATT is best (See K0BG on this). Clean, Quiet Power is the third leg of the stool.
slowmover
Fort Worth
Some pics of the install as work is underway. would be great. Help the next guy.
Where to route coax to get past headliner devices
is biggest. I’d assume it’ll go to B-pillar then to floor.
Convert QT60/AT-5555N2 for 11M
niceguy71
Massachusetts
Congrats! that's an awesome radio!!!!! I love my Anytone 5555 N II
you obviously don't fool around BillDean~!
if you post some picture of the inside of your truck I'm sure some of the guys will have some great idea's for mounting it.
I have put a few in for people and can always come up with something..... even if we have to take the console out and build a new one out of wood.... it's easier than you think and you can buy matching carpet to glue to the wood.... they come out pretty good and once done the radio and cup holders are all custom built to work perfect for that driver.
billdean
Michigan
Well that sounds interesting.. I had purchased a mount for a cup holder a week ago but not sure if it will work or not. Then @slowmover showed me a seat bolt mount that looks interesting. A little pricey but I may have to go that route. My radio and other things I ordered are suppose to be here today so it won't take long to figure out what works and what don't.
This is the cup holder mount
billdean
Michigan
On the AT5555N2 are there some set up changes I need to make in the menu for the best performance. Not sure how to set it up or maybe there is a video on that. I can do the modification for the "D" band.
Chris155
Southern Maryland
If you don’t normally have anyone riding in the passenger seat then that cup holder mount looks ok. We usually have 4, occasionally 5 seated in an 03 gmc (less interior room) extended cab pickup so I can’t do that type of mount. Those new fords sure are roomy inside.
niceguy71
Massachusetts
For me, I like to have high cut on
You should have the NB noise blanket on
And I like to run my NRC on #2 receive
And #2 on transmit
I have my mic gain up quite high ... I forget but I think it goes up to 36....and I keep mine at 32. If I remember correctly
And on the RF gain knob ....around the volume.... keep it all the way turned to the right.
SlowMover may have better settings but that works well for me.
Looking At your truck....
Just thinking
That little change holder ..storage place to the left of the cup holders..... I think that will pull out and you can set the CB in that spot .... you will lose the place to keep your spare change..... but someone here made this statement once and I thought it perfect for installing a CB
It's like getting a tattoo.... you either do it full in or you don't do it
There are brackets that keep the heat sink off the floor.... but if that change holder comes out set the radio in there.... all the wires can go under the console. . Might make a perfect install
