New feed Im trying to setup with RTL-FM. Got it working out the speakers, figured out overall how its to feed to darkice. Cept its getting dropped somewhere between. I had an old darkice setup for OP25 with a loop, cleaned it out, but no fix. Darkice is connecting with broadcastify just fine, just no output there.
/etc/asound.conf
darkice conf
aplay -l
RTL-FM & SOX
/etc/asound.conf
Code:
pcm.duplex {
type asym
playback.pcm "hw:1,0"
capture.pcm "hw:0,0"
pcm.!default {
type plug
slave.pcm "duplex"
Code:
[input]
device = plughw:1,1 # OSS DSP soundcard device for the audio input
sampleRate = 22050 # sample rate in Hz. 22050 is the RR Standard
bitsPerSample = 16 # bits per sample. 16 for mono feeds, 32 for stereo feeds
channel = 1 # channels. 1 = mono, 2 = stereo
[icecast2-1]
bitrateMode = cbr
format = mp3
bitrate = 16
lowpass = 5000
{broadcastify data removed}
aplay -l
Code:
**** List of PLAYBACK Hardware Devices ****
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 6/7
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 IEC958/HDMI [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 0: ALSA [bcm2835 ALSA], device 2: bcm2835 IEC958/HDMI1 [bcm2835 IEC958/HDMI1]
Subdevices: 1/1
card 1: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM]
Subdevices: 2/2
card 1: Loopback [Loopback], device 1: Loopback PCM [Loopback PCM]
Subdevices: 2/2
RTL-FM & SOX
Code:
rtl_fm -f 154.4M -M fm -s 16k -g 36 -l 85 | play -r 16k -t raw -e s -b 16 -c 1 -V1 -
