Alexitmisty
- Joined
- Jan 29, 2024
- Messages
- 9
Hello, I'm trying to link two PCs to transfer short data by two DP4401e like in this video:
While searching for a solution, I came across this discussion where the same question was raised:
TCP/IP over DMR through MotoTrbo
The nuance is that they stopped only at pinging, but this is not the goal of my task.
I configured the network so that both computers have a DHCP address of 192.168.10.2, the radios receive an address of 192.168.10.1. Radio ID for walkie-talkies are 12.0.19.138 and 12.0.19.139.
As you can see, the ping actually goes through. Walkie-talkies exchange with each other, their diodes blink during transmission. However, as soon as I try to check the availability of the port with the command no port is open:
I tried to add static routing, but it did not work (the picture shows an attempt to route on a PC to which a radio with RadioID 12.0.19.139 is connected).
I'm also attaching a Wireshark screenshot to show what packets are being transmitted and sent.
I also tried to exchange data through the SmartPTT utility. I set everything up according to the instructions, but at some point the following problem occurred. I register CAI Network 12. When pinging, it is 12.x.x.x, and not 13.x.x.x, that responds.
However, when setting up SmartPTT, the IP is rebuilt to 13.x.x.x.
Please tell me where I'm confused or missing something.
Code:
nc -v <IP_Destination> <port>
