APX Data Profile Type Missing
aglowgibbon
Canton, Texas
I’m trying to setup a SmartConncect profile. Under my data profile type, only trunking and conventional are showing up. From my understanding, it is supposed to show broadband only, trunking & broadband, and conventional & broadband. Any idea why it’s not showing those options?
APX 80000 running R32
I have smartconnect and WiFi flash
KevinC
32D2T/957.282
I'm everywhere Focker!
Nothing to do with your question, but how do you plan on using SmartConnect? Are you connected to a core that supports it?
MTS2000des
5B2_BEE00 Czar
That's what it is supposed to look like. You create one for trunking or conventional, populate it with the correct data like your SmartConect gateway, etc. You will also need a security certificate loaded in the radio in addition to provisioning on the core. You got all that, right?
aglowgibbon
Canton, Texas
Yes, I have everything I need to connect. It does connect and work if I set it to trunking, but I only want the data profile to use broadband only, not trunking.
aglowgibbon
Canton, Texas
Yes, I have all of the information and it does work if I set it to trunking. It has shown those options on other radios, but we can’t figure out why it doesn’t show it on mine.
aglowgibbon
Canton, Texas
Your in the wrong location. To change the setting you need to go to your personality - features....
The data section is only where you set your wifi info and put in the Broadband Gateway address
Thanks for the help. I am aware of that option, but it didn't do exactly what I wanted. I was able to figure it out with some more research; to enable the feature I was talking about, you need GA09011 Third Party Data Modem Tethering in the flash.
aglowgibbon
Canton, Texas
OK. I guess I missread what your trying to do. Not one of my 8000 or 8500 have that in the flash and all work on SC just fine. It appears your trying to force data over to wifi.
This is exactly what I wanted to do. My smartconnect worked just fine without that in the flash, but I want all of the data to go over WiFi and only audio on RF.
SCFDCOMM
We use SC, so I understand what you're saying, I am curious though, why all data over wifi? What happens if you're OOR for wifi?
What kind of data
