Database comment>Ontario Fleetnet
woody_461
Windsor Ontario,Canada..Eh?
I've noticed analog talkgroups in the OPP column.They are in the 39XXX range.I believe they should be moved to the correctionals column instead.Can somebody check into this, please?I recently identified Windsor Jail in this range.Transmissions are short, so they are hard to identify correctly.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Your best bet is to Private Message either Mike Oxlong or Thunderbolt
(Database Administrators) as they are most familiar with that system.
This forum is global in nature and your question would be better directed to the Eastern Canada Radio Discussion Forum to get their attention.
woody_461
Thanks bud!...Already mentioned this in ECR discussion forum.Maybe it was missed because it was part of another discussion.
woody_461
Okay, Pm'ed Mike Oxlong.He took care of it promptly.Nice work Mike!
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Next time if you want quicker service, submit your additions/corrections using the submission form. That's what it's there for.
This forum is more for help with the forums and/or use of the database. I don't read it very often.
A more appropriate forum would have been the Eastern Canada forum.
However, the submission form is the best way to go. That way all the global database admin's can see the submission and work it.
