Database Error
kf8yk
Anyone know how to fix this error? Pager just stopped working while in normal use, not during programming or firmware updating.
Tried overwriting the profile with a saved copy, updating the firmware, and writing a simple default profile; still stuck with this error.
w2lie
New York DB Admin
Long Island, NY
Try doing a HW reset
G2-G5 HARD RESET INSTRUCTIONS:
1. Remove the battery for at least 5 minutes.
2. Make sure pager is turned OFF, then replace the battery.
3. Plug pager into the charging cable & power supply for at least 2-3 minutes (use the micro-USB power cable & power supply included with each G4/G5).
4. Turn pager ON and then back OFF.
5. Once the pager has been in the off position for a few minutes, you should be able to press the center joystick button and see the charging indicator once again.
6. Allow pager to continue charging until battery shows full charge of 100%.
