Database Error
kf8yk
Anyone know how to fix this error? Pager just stopped working while in normal use, not during programming or firmware updating.
Tried overwriting the profile with a saved copy, updating the firmware, and writing a simple default profile; still stuck with this error.
w2lie
New York DB Admin
Long Island, NY
Try doing a HW reset
G2-G5 HARD RESET INSTRUCTIONS:
1. Remove the battery for at least 5 minutes.
2. Make sure pager is turned OFF, then replace the battery.
3. Plug pager into the charging cable & power supply for at least 2-3 minutes (use the micro-USB power cable & power supply included with each G4/G5).
4. Turn pager ON and then back OFF.
5. Once the pager has been in the off position for a few minutes, you should be able to press the center joystick button and see the charging indicator once again.
6. Allow pager to continue charging until battery shows full charge of 100%.
hazrat8990
Wyoming
If a hard reset doesn't work, you may need to re-flash the firmware.
kf8yk
Didn't work.
Flashing to the latest (V2.05) didn't work either.
What did work was this procedure:
Press the 'Main Menu' button & select 'Function Settings'
Then 'Factory Settings'
Then 'Clear All User Data', press the blue triangle a 2nd time to confirm.
The hard part is you only get about 5 seconds from power up until the pager locks up with 'Database Error', once the error appears the only option is to power off. To make navigating the menu faster I programmed a profile where only the 'Factory Setting' function is present. This setting is in section E8.2 in the Unication PPS. Even with this it took several tries to navigate the menu structure fast enough:
