Dearborn Rouge
Dailypress
Taylor MI.
When searching the ford rouge plant How do we find the
control channels. The frequency's listed on this site are wrong.
Tattoooz
Foley, Alabama
I've been looking for info on this for quite a while now with very little luck. I have programmed a couple of DMR systems that let me into a small amount of the security detail radio traffic in and around the Rouge. I've also picked up some engine plant traffic using my older PRO96, but that was from within the complex itself. Here are a couple of links to the DMR systems which you can try:
https://wiki.radioreference.com/index.php/ComSource_Michigan_DMR_Dearborn_1_DMR_Bandplan
https://wiki.radioreference.com/index.php/ComSource_Michigan_DMR_Dearborn_2_DMR_Bandplan
Let me know how they work for you or if you discover any other trunked systems or frequencies for the Rouge Plant.
I reside in Taylor, about 10 miles or so away and I haven't searched any traditional non-trunked frequencies for Rouge traffic lately. Good luck.
Dailypress
Taylor MI.
This is what I have found on the Ford Rouge
935.3875
935.400
935.4125
935.4250
935.4375
935.9000
935.9250
936.9125
936.9625
937.4125
937.4250
937.4375
937.9625
937.9750
938.3875
938.4125
938.8875
938.9375
938.950
Tattoooz
Foley, Alabama
You said: "Will DMR work on a pro 651? If you could tell me what you hear on dmr in rouge do you here like 101 to 102 cars?"
I'm not sure about DMR working on a Pro 651, but I bet someone here on these forums would.
Regarding the frequencies you've listed in your message are these the ones you're referring to in your other message?
You said: "We have been picking up the rouge for years its a very busy system like Detroit but there was some talk groups we could not get and I found out why they added some frequency's over Christmas break and now we have them all of them and its not DMR its 800 trunk system. I work for Detroit Newspapers part time and I work Full time inside the rouge and if you want the frequency's and Id numbers I have ..."
It appears that the frequencies you've listed may actually be a DMR system. Check here https://www.radioreference.com/apps/db/?sid=1459 Site 002
I've reimported the DMR systems listed above into my TRX2 and I'll let you know if I hear any traffic.
The only thing I really pick up from the COMSOURCE systems are "Requests for permits", "Requests for Access to secure areas", etc. I'll keep you posted and thanks for the info.
Golay
Nankin Township Michigan
Rouge UHF
I get rouge security on 463.300
rouge medico and labor 462.250
I keep meaning to dig out an old computer I got and look at the code plug for a UHF HT1250 I was asked to program. It came out of Rouge Steel, and he wanted to programmed for where he was working.
I know it was all repeaters. If I remember right, they were all "splinter" frequencies.
4 digits to the right of the decimal point.
Sorry, I keep forgetting until I see this thread get brought up again.
Golay
Ford Rouge Steel frequencies
I did a peek on the FCC ULS search page.
Do a query in Dearborn, with a search range of 460 to 470 MHz.
Click on the Servestall listing, and open the frequencies tab.
Those are the frequencies I'm talking about in the previous post.
