I've been looking at the BCD325P2 portable to go with my 996P2 but I just came across the BCD436HP. I don't need that zipcode programing feature, so would it be worth the extra money? (Hey, the gov wants me to spend that stimulus check)
I have the 325P2 along with its cousin, the 396XT.I've been looking at the BCD325P2
If the 996P2 does well with your local systems, then the 325P2 should perform about the same.I've been looking at the BCD325P2 portable to go with my 996P2 but I just came across the BCD436HP. I don't need that zipcode programing feature, so would it be worth the extra money? (Hey, the gov wants me to spend that stimulus check)
I forgot to mention that earlier this month (see this thread), Amazon had the 436HP at $370.09. (It's up at $439.00 at this time.) But they periodically drop it back down to the ~$370 range every month or two. The normal price for the 325P2 is pretty much in the $370 range, without the frequent price drops. Amazon also currently lists a 436HP from "Amazon Warehouse" for just under $350.00Unless money is very important, I'd go with the 436, if I couldn't get an SDS100, over the 325. Yeah you would have to duplicate programming because they are different. I don't know where in New Jersey you are, but I bet there are a lot of simulcast systems and the SDS 100 is great with them, where the other two are not.
The 325 has a lot of memory limitations if you listen to a big statewide system, which the 436 does not.
In your case, get the SDS100. If you are in Cherokee County Georgia, you have the Cobb Regional Radio System in your area. That is a simulcast trunking system. The SDS100 was designed to be compatible with simulcast systems, the 436HP was not. I have had both, and the SDS100 performs significantly better on simulcast systems in my area.I am trying to decide about the 436HP .vs SDS100. The SDS100 came out not too long after I got my 436HP. I found the 436HP a little deaf and was wonder how the SDS100 compares. If anyone has both, can you comment on how the two radios compare?
I have two 436HP's, as well as one SDS100. With several systems duplicated over both models, using the same antennas, I have not seen enough difference to notice. Even on some of the weaker systems in the area, there's not one that the 436 picks up "better", or that the SDS100 misses calls. These all have basically the same antenna; one of the 800MHz antennas, now distributed by Remtronix. The only difference is that the one on the SDS is the version made specifically for the SDS100, that mounts in such a way that the water resistance is maintained. For the 436HPs, I'm using the SMA to BNC adapter that came with them.I am trying to decide about the 436HP .vs SDS100. The SDS100 came out not too long after I got my 436HP. I found the 436HP a little deaf and was wonder how the SDS100 compares. If anyone has both, can you comment on how the two radios compare?
I have both. If your local system is simulcast, the SDS100 is going to outperform the 436 because it is specifically designed for simulcast. For other stuff, their performance is pretty similar when both are connected to the same antenna via a multicoupler.I am trying to decide about the 436HP .vs SDS100. The SDS100 came out not too long after I got my 436HP. I found the 436HP a little deaf and was wonder how the SDS100 compares. If anyone has both, can you comment on how the two radios compare?
What program is that running?Running it on my 536. I like it.
I goofed and posted that here by accident. It's a MAC scanner control program someone came up with..What program is that running?
Jim
Probably should start your own thread on this. You're asking about two totally different radios from the original question.I am trying to decide about the 436HP .vs SDS100.
Originally, GRE manufactured the PSR-600. They made the same scanner for Radio Shack known as the Pro-197. When Whistler bought the rights from GRE, they made the same basic scanner for Radio Shack known as the Pro-652. The WS1065 is essentially the same scanner as the Pro-652.I have an older radio shack scanner that looks just like the Whistler WS1065 so assuming that when the Rat Shack went bankrupt that Whistler acquired the goods.
