Deciphering Jaguar hardware error codes?
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
I'm not "in the loop" on how to decipher hardware error codes on Jaguar or other portable radios.
The manual is VERY sketchy about them. It'd have you believe you get just one two-digit
error code, but that's not what you really get. They usually start with HARDWARE ERROR
0060 and then several more digits.
What's the key to decoding the whole string of error numbers?
Elroy
WCRadioGuy
Salisbury, MD
I think the manual seems to explain them quite well. I've never had an issue between the radio error and the manual.
Elroy
ElroyJetson
I'm getting, for example, a hardware error message showing 0060 on the first line and in the second line there are eight more digits. How those additional digits are relevant is what I don't know.
I'd presume that 0060 indicates a DSP error, per the manual. But what about the other digits?
My problem is simply that the manual doesn't tell me how to handle the entire error message.
Elroy
WCRadioGuy
Salisbury, MD
I don't recall ever seeing a second row of digits. Can you post an example or screenshot?
Elroy
wiliki46
Looks like one of those error codes Jags get when they have the weird flash that enables everything.
