Decoding DMR SMS messages.
3jaz
Hello Everyone
First of all thanks for this amazing site and DSDPlus software which has made my life alot easier. Now to the question. I have been using DSDPlus to decode voice calls but is there a possibility to decode the sms message. I have a DMR radio and when I send a sms message the DSDPlus status windows detects it and shows that it had received a data header. I know the voice calls are saved in .wav file but i don't know if it save that data packets some where.
Any help regarding this would be very much appreciated.
Once again thanks for every thing.
3jaz
jhampton2000 Thanks man it worked. DMRDecode gives the binary bit stream of the message and when I convert it to ASCII I get the original message. Thanks Dude
henrygb
Really it work? i tried it many times without luck. How did you convert it to ASCII?
SignalPatcher
Only if I use the key, I get a result like this:
henrygb
And i have the same thing, only symbols without letters or words, this is with mototrbo no encrypted. Maybe it work with DMR
3jaz
Guys i am using hytera and it works just fine as mototrbo is also a DMR so it should work with it. I have got hands on one of mototrbo dmr base some how and let me see it it decodes it.
henrygb
Maybe I'm doing something wrong. this is a sample using dmrdecode
Slot Type : Colour Code 1 Data Header
Proprietary Data : MFID=16 (Motorola)
0001000101110011000000000000000011111001011111011000001110000110
17:22:30 DMR Data Frame (BS)
CACH : TACT AT=1 Ch 1 Continuation fragment of LC
Slot Type : Colour Code 1 Idle
CACH : TACT Ch 2 Continuation fragment of LC
Slot Type : Colour Code 1 Rate ¾ Data Continuation
000000011010111000000110000010000111111101110001111100110111000010110100001010001110101110100110110110101011110010001000001011101011100001010001
CACH : TACT AT=1 Ch 1 Last fragment of LC
17:22:30 Short LC : Act_Updt - No activity on BS time slot 1 : Individual data activity on BS time slot 2 Hashed Addr 174
CACH : TACT Ch 2 First fragment of LC
000000100010100010100011001011010100001100010001101111000101011101000101100101001111010110000101011000100111000110001001001110001000011101001000
17:22:31 DMR Data Frame (BS)
000001000101001100011100111111101011011000111011011111100000000000000000000000000000000000000000000000000000000010111101110000010110110001001111
first question, this is sms data?
if "yes", can somebody try to decode it to ASCII?
Saint
Fort Erie Ontario Canada
DECODE
I tried to decode this and all I get is mumbo jumbo, it make no sence,
Steve
RonnieUSA
Rowan County,KY (Morehead)
I tried to decode this and all I get is mumbo jumbo, it make no sense,
Steve
How, and what are You trying to decode with?
The reason I ask is the only DMR I receive is utilities, and it couldn't be much more than a job ticket, or directions to where they are going next.
Saint
decode
Just wanted to see if messages could be decoded
Steve
3jaz
Are you sure that the communication is not encrypted because
The line "Proprietary Data : MFID=16 (Motorola)" can mean that they are using encryption.
henrygb
Always think, that line identify mototrbo wich is motorola protocol. Dmr is a protocol compatible with mototrbo without some functions. This reason I think decode sms only work with dmr
3jaz
It works just have a plain capture of dmr.
