lgentle
Anybody use them? Was using Diskeeper for, well, forever. Started getting BSOD's. Had to run chkdsk. NOT fun on a TB disk (takes well over an hour)! Just installed O&O. Will see.
I'm currently using Disk Defrag - Reclaim the Speed Of Your Disks
No problems, yet...
What brand and model is your hard drive btw?
You should only defrag at least once a month, if that. Unless your like me and space is ruining dry and/or constantly moving massive amounts of data where fragmentation will be high. CD images on drives are a no, no. I have several of those and need to create a partition for those along.
I also use Ccleaner in conjunction with AusLogics Registry Defrag.
Might also be interested in these. ERUNT and NTREGOPT
One more!HD Tune If you run it, click the health tab, I'm curious.
Just use Contig.Anybody use them? Was using Diskeeper for, well, forever. Started getting BSOD's. Had to run chkdsk. NOT fun on a TB disk (takes well over an hour)! Just installed O&O. Will see.
Seagate 1 TB ST31000340AS
Health Status: Ok
Yeah. Images are "bad". Use them A LOT. Try not to keep to many on my drive, though.
I had/have Diskeeper/O&O set to defrag when it is needed.
if you had 7 or Vista you really dont need a defrag program
+1 on Auslogic's Disk Defrag, and CCleaner! I haven't found anything faster than Auslogic's Disk Defrag. No problems of any kind.
Make sure to run AusLogics Registry Defrag. after Ccleaner...
