gatorhater
6096 is Jail 1
Why cant I pick up anything(Fire) on the new DeKalb System? Seems to have gone silent early this morning(May 28). BCD 996T with latest freqs and TG's programmed in.
Larry, thanks for the reply. Im wondering if it is "user error" since I actually had someone program it form me while I walked them thru over the phone but we went slow and Im pretty sure we got everything correct. I checked CC's and thats what we put in. Are you(or anyone else) currently hearing traffic from DKFD? I havent heard a word. Thanks again
Did they program it manually, or, using software? Just out of curiousity, where are you located? I know when I get out of the RF hole I live in, De Kalb comes in loud and clear.
Larry
Larry, they programmed in manually. Scanner is located near P.I.B. and Jimmy Carter Blvd Norcross area.
Larry, also I had old DeKalb system in and sounded pretty good so just wasnt sure if they went encrypted for the digital switchover.
Here are some things I would check:
1. Make sure all the CCs are programmed and that no other freqs are programmed
2. Make sure the DeKalb system is programmed as a "P25" system; if it's input as a standard Motorola 800 MHz system, it won't work
3. Make sure the Lockout is set to "unlocked"
Part of the problem with the Uniden scanners is that once you program them, to my knowledge, there's no way to go back and be sure it's input as a "P25" or "Standard Motorola" system.
Yell if these things don't work. I'm willing to bet it's programmed NOT as a "P25" system
Mike
is norcross pd on this system?
To prgrm mine, the steps are.
1 System type: Conv, Mot type 1, Mot type 2/P-25, Edacs etc
2. I click on Mot2/P-25, then edit site, new site, then it gives options, and once I select the P-25 option, I no longer get the option to use CC's only. Only if I select Motorola does it leave me that option.
