Delaware County Digital System (P25) Status
shirsch101
West Chester, PA
Has the proposed new P25 for the county been put into operation yet?
Have the frequencies been released?
soberbyker
Delaware County, PA
Not sure if it has anything to do with it but this morning on some "countywide" frequencies I heard them doing a lot of testing. At one point I heard them mention something about if simulcast was making a noise, but I missed the meat of the conversation.
Whiskey3JMC
Lemme show ya sumthin
Simulcastylvania, TE
I've got the new TRS frequencies programmed in a FL on a few of my scanners, no control signal yet. What specific countywide frequencies were you hearing the testing on?
soberbyker
Delaware County, PA
I'm not sure because the scanner is background noise where I can't readily see the freq. That said, what I have as 'county' on my scanner is the Sheriff, Command, & clean. I could see the flashing color on my Pro 197 it matches those I listed.
Whiskey3JMC
Click any one of the licenses in my quote you re-quotted. They're all listed there (same frequencies, different licenses) Nothing is online yet so therefore nothing can be submitted to the RRDB
soberbyker
Delaware County, PA
Gotcha, this one is a couple blocks from my house:
41031114LTOWER106.4113.433.22407 Market Street (PA15846-A)
soberbyker
Delaware County, PA
Nope, just a spot check on a simulcast channel
I didn't know Delco was a simulcast system I guess that's what caught my attention. I thought simulcast was for a trunked system. I have been a scanner listener since they had crystals, don't know much about the how it works end.
Whiskey3JMC
New TRS indeed will be simulcast but I'm pretty sure the simulcast mentioned on air is regarding the 6-site simulcast DMR conventionals licensed to the county as a back up for when tropospheric ducting & other issues with the legacy T-band conventional system become an issue. See this posting for more info on that
462.9625 & 463.1625 both DMR conventional CC-8
cavmedic
Pottstown Pa
Negative, there are quite a few simulcast channels currently in the county on the analog and those DMR frequencies you mentioned are not simulcast.
EDIT:
Wait , wrong quote response.
Yes, the NEW system will be simulcasted p25 phase 2 as already mentioned.
Currently there are a few simulcast channels on the analog system, one of which was being tested today.
Yes there is a DMR simulcast system for backup during tropo , but the expired license one you posted is not simulcast, but IPSC
