Hi all, I've been a little confused with the different type of p25 systems coming out and haven't had a lot of luck monitoring them.
Most of the time the Delaware P25 network just shows up as dat no voice, periodically I'm getting half a conversation. I have same issue with philly and Maryland.
I know Delaware's System is Motorola and is using tdma now, so should the system be set up now as x2 tdma in the uniden scanner, not Motorola? The reason I ask is from time to time it doesn't seem to track correctly gives out control channel noise from time to time, I've also noticed a few firehouse company channels that give out a noise sounding like encryption but I thought it just skip channel on its own when encryption is in use.
perhaps the issues I'm experiencing have to do with the band plans? I'm not sure how to figure out what to put there. I have wilmington towers as standard because it didn't need rebanded. But I'm not sure about the other Motorola towers or p25 towers. When I added towers from sentinel it says 25khz spacing, seems to me like it should be 12khz spacing if this is all narrowband.
Thanks in advance
Thanks in advance
