n5gqb
So tell me how to do a dept hold on a dept that the scanner is not currently stopped on? I would like to able to go to a particular dept and hold on it without having to wait for the scanner to stop on that dept with activity and then press dept hold. At times I have been able to do it (see below) but other times it doesn't work. Cannot figure out if its a glitch or operator error or some other random unrelated setting or state of operation thats causing it to act like this.
To explain better, I am monitoring only one p25 phase 2 non-lsm system with many depts and tg's in each and 5 sites it cycles thru. No priority or wx activated and no depts are locked out. At times I have been able to press "dept hold" (while scanning) and then turn the knob to scroll to desired dept and then press hold again. Scanner would hold on selected dept. Yet other times I would do this exact same thing and scanner would resume scanning as soon as dept hold was pressed the second time on desired dept.
The scanner has no issue holding on a dept when hold is pressed while that dept is active. If you turn the knob or press hold again (while still on orig dept) it will resume scanning in a second or two, hence why I pressed hold a second time when scrolling to a different dept to hold on. Here again, sometimes it'll hold and other times no. Any idea?
Thx Sly
Thx Sly
