Diamond Antenna Cr-8900a
mlconnell
El Paso, TX
I am contemplating buying this antenna for my Yaesu FT-8900R Quad Band Mobile. I noticed it attaches to a UHF connector but does not come with the Mobile Antenna Mount. Giga Parts does not recommend this being used on a Magnetic mount as it needs to be grounded they say.
My question is can I used like a lip mount and mount it on the lip of my trunk where it closes? Also is RG-58 okay to use with this antenna?
I am wanting to mount it on my 2008 Mazda3. Any suggestions would be greatly appreciated. Thank you for your suggestions and expertise in helping me getting this antenna mounted.
methusaleh
New England
I've run a few of those antennas over the years, several using clamp-on, trunk lip-style mounts, and have had success.
RG58 or RG8X should be fine if you are running only 12-8 feet of coax, unless you really need high performance on UHF.
