Diamond DJ130
airgreek
Ohio
So I have found three places that sell this antenna but I am not sure if it comes with the N connector. Can someone help me since I know jack about this hobby?
iMONITOR
Silent Key
S.E. Michigan
The Diamond version comes with an SO239 that accepts a PL259 (CB type) connector. The one marketed by ICOM comes with a Type N connector.
N3LLO
New Ipswich, NH
Diamond has two different models of essentially the same antenna.. the D-130J with the SO239 and the D-130NJ, with the N connector. If you plan to listen to UHF/800, the N connector will likely perform better.
Hope that helps,
- Matt
airgreek
Ohio
Hope that helps,
- Matt
Thanks but where can I buy the D-130NJ?
commstar
D-130NJ Source
Just purchased and installed a D-130NJ replacing a D-130J (+/- 20 years of service).
Made a noticeable difference here- especially on VHF.
I have no affiliation with this company aside from being a satisfied customer. Online ordering,good price, quick shipping and direct pass-thru of actual shipping charges.
http://www.rlham.com/cgi-bin/shop/modellookup.dbw?MODEL=D130NJ
usnasa
Brooklyn NY
Hello
How would that antenna (D-130NJ using lmr 400) do inside near a window ?
I live in a condo ground floor and antenna mounted outside is not allowed
iMONITOR
Silent Key
S.E. Michigan
Hello
A D-130 would be really big and bulky to have inside your condo, especially by a window.
airgreek
Ohio
Just bought one also from the same place. I wonder if they give discounts to radioreference members?
usnasa
Brooklyn NY
thanks airgreek
do you really think it would be better than the one I have now for indoors ? have you tryed it
airgreek
Ohio
thanks airgreek
I have one that I currently use with my BCT8 and signals come in SO MUCH better than any rubber ducky, magnet mount antenna I have ever used. Trust me it will be the best $30 you have ever spent.
Paulsan
York PA
usnasa, have you tried putting your magmount on a cookie sheet or pizza pan?
usnasa
Brooklyn NY
yes Paulsan I currently have it mounted on my tripod on a piece of metal in front of my window
here is a pic
Mikey54
Ontario Canada
here is a pic
That's not enough metal. The metal is to act as a groundplane for your antenna. It should be close to a 1/4 wavelength at the frequency that you are listening to. If you can't do that, fasten some wire radials of the appropriate length to the metal base. That will improve your reception.
usnasa
Brooklyn NY
thanks Mikey54,
I am mostly listen to 800 's freq , the metal I am using is a four inch Electrical outlet box cover, the antenna itself is 36 " high, ( I WAS READING somewhere that a 28" x 28" plane of metal for 800 is good but thats a little crazy too big lol I would rather try the wire radials , Question is
how and where would I attach it and what length and what type of wire to use .
thanks again
