Did You Do The Firmware Upgrade? (106/197)
intrepid97
I personally have not as I have no issues with my Pro-106 and do not want to fix what is not broken.
I was just curious as to how many others may not have upgraded as well and why you decided not to as well?
jblake76
So.Jersey
I was told that this can't be reversed. Only dsp updates can be removed. Is this true or not?
torontokris
Toronto Canada
should be able to just upload 1.6 over it without a problem.
it doesnt make any big changes anyway (just small ones), so dont think it will cause major problems
191145
Saint Francisville, LA 70775
+1
I can't count the number of times I've upgraded something digital & regretted it cause - it wasn't broken.
Also, to go back to the previous version, you have to have that version somewhere - where did you find 1.6?
JP
kd7ckq
No. AZ
I cant tell what happened or when it happened. But, I seemed to have noticed it after I did the upgrade. Before I would hook up my USB cable cable and hear audio while using WIN500 client from another location. Now I cant. I have to hook a audio cable to the headphones out to get audio. Before it was only the USB cable hooked to the PC/IF jack and that would also pass audio. Anyone else experience this?
rdale
Lansing, MI
Absolutely not... Audio only comes out of the audio output. The PC/IF jack only sends data.
NDRADIONUT
FARGO ND
Do you have the record box selected for each freq you want audio from ?
kd7ckq
No. AZ
I didn't know this little tid-bit before until I heard about it here on RR.com and tried it. I would run the PRO-197 with the USB cable only and the BCD396T into the Mic input on one laptop.
The last time I tried this was with WIN500 v1.82 and CPU 1.6. I now run WIN500 v1.86 and did the CPU upgrade to 1.7. I just tried to do the same set-up with no luck this time.
rdale
Lansing, MI
Again - you NEVER got audio out of the Pro-197 with the USB cable only.
