SDS 200 programing questions
RadioMarkW
Illinois
I have a couple of questions on the SDS200. I currently have a 996p2 which I love and can customize EVERYTHING.
The ONLY reason I am looking at the 200 is for the simulcast sites.
Here is what I want to know:
1. Do you have to use the full database or can you download just the sites and information you want (as I do now)? (Loading the whole database seems way too inefficient to me, loading states and systems I will NEVER use.)
2. Can you customize all the names and information (as I do now, sometimes the tags on RR are just a bunch of letters and/or not a very efficient descriptive)?
I know about the 200's "Favorites" thing but just how many different lists can you have? I set things up county by county within each state I do monitor as I travel, so use a LOT of lists. The 996 allows up to 99, does the 200 also?
AND finally just how well does it do with simulcast?
Thank you!
jtwalker
BEE00.1E8-1.22 (or) BEE00.689-1.13
To get the look and feel before you buy, you can download Sentinel for x36 now and try it out. You don’t need to use full database and you can customize alpha tags to your heart’s content.
And lastly, I think it does dang near perfect with simulcast systems … as long as you are not in a high RF interference area (cellular, tv, radio, whatever transmitters).
Enjoi19
Ontario, Canada
1. You can just use what you want. I've never used the database for scanning. If you're used to making your own lists, have at it. It is a different format than the 996-series so it takes a minute to wrap your head around the new formatting.
You can also chuck the garbage that is Sentinel out the window and use ProScan + your premium membership to make your favourite lists without feeling like you need to smash your head off the desk every 5 minutes.
2. Yep, you can do all that.
3. If you're looking to handle simulcast, it handles it pretty well and will be night and day compared to other scanners.
kc2asb
NYC Area
For the record, Sentinel is not garbage. I have been using it for nearly 10 years to program and update the firmware on my 536HP. and never had any issues. It never seemed particularly difficult to make favorites lists.
Sentinel should be perfectly adequate for the SDS100/200 also.
Just my 2 cents.
hiegtx
Dallas, TX
You could use the full database if you were traveling in an area unfamiliar to you, and were also using a GPS. When used properly, with location control active, the GPS will have the scanner monitor only those systems, sites, & departments in the range that you selected, and whose channels matched the service types you have active.
If you created a list by appending a system from the main database to a Favorites list, Sentinel will append all the sites in the system, though you can carefully select only the departments that you want. You can either delete the sites out of range (and/or not of interest), manually set the unwanted sites to "Avoid" (locked out), or let location control only select those in range. I prefer to delete the ones I don't want, but some users prefer to leave them in the favorites list, and let location control select only those in range. Their preference for that, versus deletion, is that maybe at some point you might travel to those other areas and would want (or need) those currently 'out of range' sites. (I prefer deletion. I can always quickly add back 'out of area' sites that I might need access to while traveling.)
If using software, such as ProScan or ARC536, you can import only those systems, sites, & departments that you specifically want. You, of course, can also manually create a system using either software, including Sentinel, or directly on the scanner via the keypad. Note that ProScan can also import the files from your 996P2 and use them to create Favorites lists. I prefer ProScan, both because of it's features, but also it covers many other Uniden scanner models, including a number that were discontinued years (even decades) ago. ProScan can handle both your 996P2 as well as the SDS and x36HP scanners. ARC536 is limited to only the SDS & x36HP scanners. It uses a different program for the 996P2 and 325P@, plus the 396XT & 996XT. ProScan, @ $50 license fee, covers all these scanners (and more), and includes virtual control, logging, & other features. ARC536 is about $40 for the Basic version, which does programming. If you want virtual control & some of the other features, you have to pony up about $70 for the "Pro" version. Sentinel is required to update the master database in the software as well as on the SD card in your scanner. While firmware updates have been few & far between after the unfortunate passing of UPMan (Uniden's product manager), any firmware update, if & when issued, is processed via Sentinel.
You can customize the name of a system to whatever you want. I generally shorten the sometimes long 'official' name from the database to something more compact & familiar to me.
Your only limitations on Favorites lists is that the size of a list cannot exceed one megabyte in size, which leaves you a lot of room to include whatever you want. Create as many as you like.
Your other 'limitation', if you want to call it that, is that you have 100 quick key numbers to choose from, for your Favorites. You cannot assign the same quick key to more than one system. However, a quick key is not required for programming; it's only a convenient shortcut for you to use in selecting specific systems, and turning them on or off more quickly.
As jt & others have noted, the SDS series scanners do handle simulcast well. In my metro area (DFW), all of the larger trunked systems in service use simulcast sites, The SDS scanners have no problem with them.
dmfalk
Eureka
Also, for firmware updates, Sentinel is required. The other software doesn't do firmware updates, and the SDS units don't come updated. (Also, using the full database, you can use zip code location, instead of GPS.)
(I have the SDS100.)
