Difficulty Understanding BC92xlt Features
ASE
Canada
I have the BC92xlt and I am having trouble understanding the instructions in the manual that came with it. The difficulty is with Func PSrc and with Close Call. With Func PSrc I choose the bank and it says to choose upper and lower limit. When I do that nothing happens. With Close Call I choose func and hold for two seconds to choose the options. After I choose the options what do I press after that. Just scan? Does anyone have easier step by step instructions?
Thank you.
ASE
rwl48
MA,
Hi
This is not much help but there no easier step by step instructions. Just read the instructions carefully and be patient and it will get easer and easer.
Good luck
ASE
Canada
Hi. Thank you. I have been getting the hang of it. Something that I don't understand is why the purpose of Close Call if you find those frequencies during a normal search?
KMA367
Redwood Coast, N Calif
Close Call will "hear" and alert you almost instantaneously as soon as a strong transmission is detected on any frequency in the freqs/bands it's set to.
In a normal search, it's likely to be constantly interrupted by even weak/distant signals on any of the freqs you're searching. Plus, the nearby/strong signal will only be detected if the scanner is passing by that freq at the same time it's transmitting.
