Disaster Preparations
KQ4AQP
Cadiz, KY
Hypothetical Planning In A Real World - Legalities aside (for emergency/disaster utilization only) [Tornado, Hurricane, Earthquake, Flood, Forest Fire], is it even possible to have good CLEAR communications with minimal background static/noise with the following parameters?
• (1) 50-watt radio transceiver (unlocked) with battery backup
• (1) Multi-band antenna (height TBD based upon location and terrain)
• Ability to hit existing repeaters within a 50-mile radius
► 2m
► 1.25m
► 70cm
► GMRS
KQ4AQP
Cadiz, KY
The problem with either amateur radio or GMRS is who are you going to talk to and will they be able to help you in an "emergency".
Understood, which is why maximum versatility in communications is key.
kb5udf
Louisiana
You may have trouble finding one antenna that covers all of those bands with a fair amount of gain. There are vertical antennas with modest gain that will cover 2m, 70cm and GMRS. As far as hitting all repeaters within 50miles, impossible to say without more information. Most situations would require you to accept hitting some of the repeaters once they are past 30mi as opposed to all of them, given a tower that most hams likely have at their QTH. Regarding mobile use, same thing, and in my experience in flatland here, reliable 2m meter mobile coverage out of 50-60 miles needed repeaters with antennas high up on towers like 600ft plus. However, throw in some hills/mountains and things can change a lot.
Concrete simplistic example assuming flat terrain the vhf uhf line of sight calculator says if you have a 200ft repeater and even with a rather tall (for a ham) 100ft tower, your range is still only 34 miles.
For a more realistic ham tower height of 60 feet you get 35 miles for a repeater at 600 feet. In practice, at least on 2m, you can often do a bit better than line of sight calculations, but they give a useful starting point.
All of this assumes you are using a vertical. If you find a suitable beam antenna, you can stretch range even further, but at the cost of not hearing everything you want to hear at the same time given directivity.
KQ4AQP
Cadiz, KY
Gotcha, especially with the curvature of the Earth (height is everything). As for frequency range, would a discone antenna be a viable option?
While mostly intended for scanners, most of them indicate the ability to also TX on 6m, 2m, 70cm, 33cm, 23cm; and they are omnidirectional. And yes, there are a LOT of hills and forests between my location and many of the repeaters. Unfortunately, most of the areas with repeaters are farther away from center location (see map) so, as indicated, versatility is key - who's listening on which band in what direction and able to respond ...
This whole scenario is a result of the recent tornados that wiped out much of West Kentucky, including Mayfield, where I have family. I was NOT able to raise anyone on 2m or 70cm (no one monitors the 70cm repeater right here in my own county), but WAS able to contact a couple of people over GMRS. Again, maximum versatility is essential in such a disaster.
Thank you.
trentbob
Silent Key W3BUX
Bucks County, PA
► 2m
► 1.25m
► 70cm
► GMRS
Interesting topic and there have been other threads if you check in the recent past on similar topic.
The scenarios that you have identified are serious but tend to be Regional, they come and they go, usually just leaving a power failure, maybe lasting a while. Along with damage and loss of life. Radios should work ok as long as the batteries last or with generators.
If it is a national or Global emergency, I think you know what I'm saying, then you have a different set of factors to deal with like EMP etc etc.
That's a different challenge, as has been said, who you going to talk to that isn't in the same boat and... will talking on the radio be a priority at all.
In that scenario I think I would depend on 2 m simplex, see who's close.
Before we go too far down this rabbit hole, and since others who don't understand FCC rules will be reading this in the future, lets cover something really quick:
Amateur radio, GMRS, FRS, MURS, CB radio FCC rules do not change when there is an emergency or disaster. None of the FCC rules permit any different operations when there is an emergency/disaster. The same rules apply as any other time.
Amateur radio operators are restricted to the amateur radio frequencies and power limits under all situations.
GMRS users are restricted to the GMRS frequencies and power limitations.
Same with FRS, MURS, CB, etc.
There are a lot of people that will claim that the FCC rules don't apply when there is either a real or perceived emergency. FCC has made it clear and backed that up with enforcement and hefty fines (plus, getting it plastered all over the internet with names, call signs, etc…)
Just in case someone reads this later and is looking for justification to ignore established FCC rules.
► 2m
► 1.25m
► 70cm
Clear/minimal background noise depends on a lot of variables. Unless you have control of those variables, the answer is "no".
A 50 watt radio, "unlocked or not" isn't going to ensure you'll make 50 miles. Remember, two way radio requires appropriate equipment on both ends. Unless you have control over both ends, everything goes out the window.
Range will depend on the topography around you. 50 watts on any of those 3 bands isn't going to magically pass through mountains, hills or deep into canyons.
In a true disaster/emergency, repeaters are going to depend on power, and how robust it is. Towers collapse, power goes out, poor installation tends to show up when things get stressed. Unless you have control over the repeater and installation, or trust those that do, relying on rando-repeater in an emergency is not a good idea.
Antenna and antenna heigh make a big difference. You'd need to look at what sort of terrain you are dealing with and do your link budget calculations to determine if you even have a path to work with.
For emergencies, I'd be looking at simplex communications to remove all the reliance on "someone else's stuff" in the middle. You'd also need to make sure everyone you want to talk to is setting up their stations with the same level of quality, reliability and proper design if you want this to work.
Remember, GMRS requires proper type accepted equipment under all circumstances, no exceptions.
The rules for GMRS are different than ham, so make sure whatever design you come up with takes all this into account.
GMRS isn't going to be noticeably different than 70cm amateur from a technical standpoint. The frequencies are close enough that the perform pretty much the same. The benefit to GMRS is that it is easier to get a license and easier to get the non-technical people in your family/friends circle involved.
I'll get flamed by some for this, but I'm going to say it anyway:
Discone antennas suck.
The only redeeming value of a discone antenna is that they have a lot of useable bandwidth. They have zero gain compared to a quarter wave. Their radiation pattern is less than ideal.
If you want reliable long range communications, a discone is not a good choice. Properly spec'd band specific antennas with suitable gain/radiation patterns will run circles around a discone. Discones also tend to be a bit fragile if you are looking at those in the hobby realm. Not a good choice for high winds/damage survivability.
You can absolutely transmit with them. I have a $3000 Telewave discone antenna on one of my high sites that I use with a remote receiver for testing and as a back up antenna for some VHF and 800MHz repeaters. Yes, it'll work, but it is a poor performer compared to band specific antennas that have gain. It's strictly a wide band receive antenna and there as a backup antenna if one of the dedicated 800 or VHF antennas fail. I'd not install one as a primary antenna for anything other than a wide band receiver. There are much better choices.
With the topography you have around you, getting 50 miles of range is going to be a challenge unless there are some really good repeaters around you that will be there in an emergency.
Might be worth playing around with some of the radio propagation tools that are on line. The good ones will let you put in antenna height/gain/ERP values for both ends of the communications path and take into account local topology to give you a pretty good idea what your coverage will be. There's just too many variables to try and guess at this, and guessing wrong gets expensive really fast.
I've been a ham for decades and have held a GMRS license off and on since the late 1990's.
Neither ham or GMRS is an emergency radio service. Relying on it for emergency communications is not a good idea. There is no requirement that the repeaters be built to withstand bad weather or power outages. It's a real crapshoot. Same with GMRS.
I've tried to use both ham and GMRS in emergencies, and I learned my lesson. There's no requirement that anyone be listening or willing to help unless you have arranged all that ahead of time. In an emergency, most people are going to be looking after their family first, radio will come later. Don't rely on a hobbyist to be a first responder.
If you expect to be in any emergency situation where normal communications will fail (internet, wired telephone, cellular, etc), then hobby radio services are not the solution.
If you want reliable communications in such a situation, there are a couple of reliable options:
-Satellite phone. Expensive, but will put you in immediate communication with others.
-Modern cell phone that has satellite SMS capability. Many of the more recent iPhone and Android phones can send text messages through satellites and will get your message through.
-Satellite based devices like Garmin InReach. These will allow you to hit and SOS button and be put in contact with professionals that will get you the help you need. They also allow you to send messages/e-mails to others.
I understand what you are looking for here. Radio is a nice tool to have. It should not be the only tool you have. Relying on hobby radio services isn't good planning. Even with an unlimited budget, it gets difficult to do with any sort of reliability.
If I had to do this and my only option was amateur radio, I'd probably be looking at HF with an NVIS antenna and making sure I had someone on the other end that would be ready and listening if I needed their help. Other than that, I'd stick with the satellite phone/cell phone/InReach type device. those are the only ones I'd rely on if my life was depending on it.
MUTNAV
Thank you.
In all kindness.
Still a little unclear as to what is desired, with that in mind....
First I'm assuming when you say emergency, you mean health and welfare of loved ones and how you can help out.
If you're concerned about family, I would first go over a family emergency communications plan from FEMA,
it probably wont help a super great deal, but if you introduce the information to family (Thanksgiving-Christmass etc...), and get some talk going, you may be able to arrange for some of the people you care about to co-operate with radio licenses and equipment.
Practice / testing (at least once) is important, many people would be furious if their favorite ball team went to a big game without any practice, but for emergency communications with their loved ones, they are willing to just wing it.
I agree that versatility is nice, but if the people you want to talk to don't buy in to what you want, nothing will be versatile enough.
If your family insists on using e-mail for everything, then maybe APRS with text going through a gateway might be helpful, or as mmckenna suggests, an in-reach device.
If your family already has their licenses and equipment, then, as suggested, NVIS, or Tropo-scatter, might be a helpful mode. If you use 70 cm wide-band directional antennas (an array of bow-tie antennas?), you might be able to use them for better range on GMRS also.
IDK if this is helpful or not.
Joel
K6GBW
Off Grid Kid
Montebello, CA
Disaster communications really boils down to a plan. I live in Los Angeles and we get earthquakes. When they strike it’s not uncommon for the phones and internet to go down for a time. I have a “plan” with a friend of mine that lives about 60 miles away. We will try to communicate via two repeaters so that I can pass along my status and then he can call my family and update them. I would, of course, do the same for him. If the repeaters are out we have two 40m frequencies we’ll try using NVIS antennas at 100 watts. Our plan is to try to link up on the hour, but if that too fails we have the ability to send Winlink messages. In the last big quake I used the hell out of my 2m and 440 radio to just get information about what was going on. We initially had no power, so no TV. I also used…and still use a small pocket radio. We also both have satellite communicators that we can leverage if all else fails.
Gear will always be secondary to having an actual plan and a goal for what you need to communicate in mind.
DeeEx
New England
It’s not on the list, but having survived numerous natural disasters of minor to moderate scale in the last few years…here in rural Vermont CB was more active than anything else. Most of the traffic was simple information such as which gas stations had electricity and which roads were passable. There were a handful of elderly people on base stations whom we were giving weather reports to.
Two or three times I heard actual message traffic being passed, with isolated people requesting loved ones be called by telephone by those who had the ability to do so. There was no formal ARRL traffic net or anything, but it was effective.
A distant 2nd place to CB was 2m simplex, often the same five to 10 people I hear on repeaters all the time.
rescuecomm
Travelers Rest, SC
Not a bad idea to have stuff ready especially this year and early next year. The chances of anarchy breaking out regardless of who wins the election is pretty high.
I'm buying a 10k generator and a MSR water filter just in case. I'll have all the WT batteries freshly charged before November. I just wish my son would be more active in amatuer radio.
GlobalNorth
Fort Misery
What happens when everyone with a similar plan and gear gets on a popular 2 meter repeater and won't shut up? What happens if one malcontent turns a 100 watt transceiver into a jammer and locks up the machine?
MUTNAV
As far as jamming or interference goes, there are some well known techniques, DFing, individually, or as groups, etc...
We can only go so far down the bad actor possibilities... Rioting, looting, hording, mob rule, militarized gangs, scalping tickets, Jamming repeaters, hogging HF frequencies, etc...
Just getting communications to work without malicious actors is more than enough of a challenge for most of us.
Just my 2 cents
(why isn't there a cents key on keyboards)
Joel
Robbie1984
Kalangadoo, South Australia
I'm a 4th generation radio operator with all 3 previous generations stemming back to my Uncle and Pop (dad's father) being proficient in radio operations during WW2 as well as my father being a sparky and CB radio operator (70's-90's) when he reported quite a few fires on AM ch 9 during the 82/83 fire season prior to Ash Wednesday along with being exposed to CB, Shortwave and emergency radios growing up has allowed me to come up with my own communications setup for disasters
Bushfire (Alarm level 4)
Initial communications (If not providing spot fire patrol in the township until such time as power goes out)
* 27 MHz AM/SSB ( 1/2 wave base antenna)
* GME 370c UHF radio (4.5 DBI helical antenna)
* Tecsun S2000 shortwave radio (MLA -30+ loop antenna)
* RS 918 HF radio (sloped long wire antenna)
* Uniden 536pt scanner( multiband base antenna)
* Hamgeek APX-8000 handheld (programmed with 2m and 70 cm channels)
Field/Back up communications (In event of having to assist in establishing evac centers at the pub, primary school, local farmers market, 2 churches and football club)
GME 390C UHF radio (installed in rav 4)
* ICOM IC-2730A (installed in rav 4)
* Uniden 436pt handheld
* GME XRS-660 handheld
*GME TX6160 handheld
* Uniden UH755 handheld
Its common knowledge that during the 1983 fires which threatened after my QTH after a south west wind change came through amateur radio and cb radio were used to coordinate response of farmers as well as relief resources the local operators were apart of South East Amateur Radio Group and using the local 2 meter repeater
ladn
I wouldn't count on many repeaters "existing" after a major disaster.
  • Many repeaters depend on power lines and have little or no reliable backup power and there may be no way to access the repeater site to repair or replenish
  • The repeater/building/antenna may suffer physical damage
  • Interconnected repeaters may lose whatever mode of interconnection used to link to the network and/or the network servers may, themselves, be affected
Direct communication will be more reliable for relatively short range comms with HF a possibility for longer distances and SATCOM for connection to the rest of the world.
MTS2000des
5B2_BEE00 Czar
That is the biggest flaw in the "Baofeng prepper" mentality. Relying on someone else' infrastructure is the weakest link. As the above poster said, amateur repeaters are subject to the same outages and failures as commercial/cellular. Relying on off the shelf backhaul like cable, commercial fiber, etc is also a factor.
Hoards of equipment are only as useful as the skill set of the operator.
N4DES
Retired 0598 Czar ÆS Ø
South FL
Yup just ask Broward County (FL) how well their "amateur club repeaters" worked after hurricane Wilma for their ARES program. They called us (Palm Beach) and south to Miami-Dade looking for available repeaters because all of theirs were OOS (guess they didn't want to go simplex). I assigned one that still exists in Boca on a County tower and they used it for everything from the center of the county north to the line. I believe MDC offered them one in UHF to use to the south.
The AAR stated that the amateur grade antennas didn't survive in the majority of the locations and no back-up power.
