Dispatch console
motolover
Anyone know where i could buy one of them motorola dispatch consoles? Do they have mounts so you can mount normal mobile radios in them ? thanks
MMIC
Inside of the circuit....
When you say "one of them" do you mean the buttons and LED models? The newer Centracom Gold Elite? Or the newer, compact buttons and LED system?
At any rate, you can inquire with your local Motorola Authorized Retailer and they will be happy to sell you a console system. You can attach mobile radios into all of these options, but these systems are going to be extremely expensive new, and probably hard to find used. The systems that are not the new, compact buttons and LED system are more than just a PC, CIE, and monitor - they have a CEB sitting in the background running everything. A CEB is a card cage that contains the interfaces into the console operator position, trunked systems, conventional base stations. It also includes a clocking card for the TDM bus timing. It will also require a Elite server to serve the alias and console databases to the console operator positions.
The compact option is a smaller unit, but it is much like the older buttons and LED system and looks pretty ancient and as I recall can only support about 4 radio max.
Just want to make you aware of what you're getting into because a Motorola console system is not a simple animal.
motolover
Ill probably end up building something to hold all the radios in. Does anyone know where i can buy the faceplates that go in the mobile consoles? thanks
WayneH
Forums Veteran
Super Moderator
Your master site
So you mean something like a Troy console and not a dispatch console? You really need to be more descriptive in your messages because you're vague as hell.
Do a search on ebay. Here's an example.
Astro25
Chicagoland
I've got a cheapo Comtegra setup thru a Tone Remote Adapter to a Maxtrac in my radio room. If you can get a TNA and properly wire it up, you can have a decent small setup working.
