WS1080: Dmr frequency help
captn1232
canton ohio
Hello to all. I am hoping someone can help . I have used RR database for my local police dept. they stated it was on DMR. and noted it was NOT encrypted, see this link for Perry police Stark County, Ohio (OH) Scanner Frequencies and Radio Frequency Reference So using the ws1080 .I added knowing I have a DMR scanner, the frequencies . I aslo used the quick import, from Digital frequency, and imported. these..
155.370000,"PERRY, TOWNSHIP OF 20FB PW",DMR,-1
155.370000,"PERRY, TOWNSHIP OF 50FB PW",DMR,-1
151.272500,"PERRY, TOWNSHIP OF 20FB2 PW",DMR,-1
155.130000,"PERRY, TOWNSHIP OF 20FB2 PW",DMR,-1
155.130000,"PERRY, TOWNSHIP OF 50FB2 PW",DMR,-1
155.587500,"PERRY, TOWNSHIP OF 20FX1 PW",DMR,-1
156.150000,"PERRY, TOWNSHIP OF 20FX1 PW",DMR,-1
151.272500,"PERRY, TOWNSHIP OF 40MO PW",DMR,-1
154.650000,"PERRY, TOWNSHIP OF 40MO PW",DMR,-1
154.860000,"PERRY, TOWNSHIP OF 40MO PW",DMR,-1
155.130000,"PERRY, TOWNSHIP OF 40MO PW",DMR,-1
155.370000,"PERRY, TOWNSHIP OF 40MO PW",DMR,-1
155.587500,"PERRY, TOWNSHIP OF 40MO PW",DMR,-1
156.150000,"PERRY, TOWNSHIP OF 40MO PW",DMR,-1
I have imported conventional and added a wildcard. all I hear is garbled reception.. I have also tried different color codes. still nothing.. I do not know the TGID . so I am wondering would that help ? also if it was encrypted why would I not have the letter E shown on my scanner screen. Any ideas what I could try ?? or if I am not doing something right?? thank you for your time and feed back
troymail
Silent Key
If you've programmed them as conventional DMR and and left the CC, SL, and TG set to wildcard (*), that is all you need.
If you're hearing garbled voice, it's probably using some form of "privacy" - doesn't have to actually be formal encryption. Either way, privacy, encryption, etc - if they are using something like that, you won't be able to monitor.
If possible, capture a recording of what you are hearing and post it. Then we'll be able to confirm.
Forts
Ontario, Canada
If your programming was wrong you wouldn't hear anything at all. The fact that you are hearing garbled voice almost guarantees it's encrypted.
captn1232
canton ohio
Thanks that's what I'm thinking. .confusing because RR database does not show it encrypted. .I'm going to as the other gentleman mentioned try to upload a clip of what I'm receiving
