racingfan360
- Joined
- Dec 19, 2005
- Messages
- 1,196
I haven't been able to leave the alpha tag blank. I've been using ARC536 to clear the alpha tags. kikito, Does default mean Channel 00001?
In ARC536, you just leave the Alpha tag Name field completely blank for this to work.
Alternatively you can manually set the alpha tag to be blank (it's fiddly, but you have to scroll through for each alpha character and set each one to be a blank space: its the one between A and @).....once you have set them all blank, press E, then confirm to "Set default name". This in turn automatically sets the name to be the frequency. This "Set Default Name" is what I meant by Default.
For some reason if you set (manually or with ARC536) the name/alpha tag to be " Frequency MHz" then it doesn't work, yet if you leave it blank it defaults to " Frequency MHz", and does work. I assume the logic of the 436 means that if you've populated it with any info at all, that part if the window can't then be used to display TG Info. Weird.
