I'm in Las Vegas and trying to monitor the MGM Resorts systems. Sentinel doesn't have the system available, so I tried setting it up manually using the "MotoTRBO Trunk" type.
The scanner will not track the system - it essentially scans all the channels as single-frequency. It does not show any indication of recognizing a DMR system (No DMRT3, or otherwise)
However - Trunking Discovery mode seems to work, and shows the system as DMRT3, and the LCN finder also appears to work.
I have all channels programmed, with the LCN's from the DB. Any ideas why the scanner wont track this system in a normal, scanning mode?
Thanks!
Thanks!
