SDS100/SDS200: DMR T3 - Does it work?
Mikek
I'm in Las Vegas and trying to monitor the MGM Resorts systems. Sentinel doesn't have the system available, so I tried setting it up manually using the "MotoTRBO Trunk" type.
The scanner will not track the system - it essentially scans all the channels as single-frequency. It does not show any indication of recognizing a DMR system (No DMRT3, or otherwise)
However - Trunking Discovery mode seems to work, and shows the system as DMRT3, and the LCN finder also appears to work.
I have all channels programmed, with the LCN's from the DB. Any ideas why the scanner wont track this system in a normal, scanning mode?
Thanks!
GTR8000
NY/NJ Database Guy
BEE00
Let's start by you telling us what model scanner you have.
RandyKuff
Lorain, Ohio
Just asking... You did purchase the DMR key to unlock the DMR MODE correct?
Mikek
Yes - I have the key, and other, non TierIII, DMR works fine
RandyKuff
Lorain, Ohio
Yeah I see MGM does not show up in Sentinel's Database... But it's on RR's...
GTR8000
NY/NJ Database Guy
BEE00
That's because Uniden has not yet added Capacity Max systems to the weekly Sentinel pull, despite being told numerous times that those systems are being ignored.
Whiskey3JMC
Lemme show ya sumthin
Simulcastylvania, TE
Lee Iacocca lived in my former apartment complex back in the 50s (as did Dick Clark and Ed McMahon)
Mikek
So maybe I need to clarify my ask - Does the SDS100 support tracking of DMR TierIII systems in scan mode? Is there something I haven't don't correctly that I should check?
GTR8000
NY/NJ Database Guy
BEE00
More specifically, does it correctly track Capacity Max systems, which are not standard Tier 3 but rather Motorola's version of it.
pcbulver
Try using MotoTurbo mode and add the LCN on the second page of the site. ST6-2 MGM Grand (click)
LCN 2161 for 937.0125
so on
Mikek
so on
This is how it is currently set up.
seagravebuff60
Short Bus Reject
If I recall correctly, my SDS100 was doing fine on a Cap Max system that I monitor in Florida. It's a new system, so I programmed it as a Moto TRBO Trunk, then used the LCN finder on it, and it worked fine. But I did it all by hand on the scanner itself.
I recommend using ProScan and not Sentinel if the SDS is being programmed via the computer.
Is this the system?
