Hello RR people,
I’ve got two Motorola DP4601 (European version of XPR7350) on firmware R02.09.00.0001.
Both have a channel programmed to the same frequency, slot, color code, with unique IDs (101 and 102).
Private contacts are set in radios, no DCDM enabled.
Voice TX works, call alerts work.
But these two radios won't receive DMR text messages - neither from each other, nor from other DMR trasceiver (Anytone 578 programmed to M-SMS format).
I tried every possible combination of Compressed UDP Data Header ( None / MSI / DMR Standard) with Text Message Type ( Proprietary / DMR Standard) with Data Call Confirmed (on / off).
Anytone 578 receives messages from both DP4601 with no issues, as long as they were set to Text Message Type Proprietary, as it's configured to M-SMS format.
When DP4601 configured to Message Type: DMR Standard and Anytone 578 is set to DMR Standard too - Anytone won't show the actual message text, just the fact that there is message from 101 ID.
So long story short, all this back and forth brought me nothing but a headache.
I tried to create fresh codeplugs for DP4601s but it changes nothing.
Anyone here with the same problems on DP4601 / XPR7350?
Thank you
Thank you
