DSD F/L scrolls when on a CC
phyberoptics
Orangeville, Ontario
When I monitor a CC using a single tuner, in Combined CC/VC mode, the monitoring works as it should:
When I monitor either with 2 tuners, one in CC, the other in VC mode, or if I change my single tuner to Passive, DSD+ F/L shows and scrolls this:
Curious if I have a setting wrong? When I comment out the frequencies in the dsdplus.frequencies file the scrolling stops, so genuinely think something is not quite right.
; FastNet
;TIIIStd L13 1.7 365 422.2625 0.0 0 ; East Garafraxa
TIIIStd L13 1.7 366 422.2625 0.0 0 ; East Garafraxa
;TIIIStd L13 1.7 381 422.3625 0.0 0 ; East Garafraxa
;TIIIStd L13 1.7 413 422.5625 0.0 0 ; East Garafraxa
merlin
DN32su
It is going to do that everytime the CC broadcasts its ID.
I don't know the efect of switching to VC mode only, but something I would try.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
It is a known bug/issue. Run in Combined CC/VC Monitor mode. If you don't "want" to trunk and want it to stay on the control channel, run in Combined CC/VC Monitor mode and go into CTRL -> Call Priorities --> select Group Voice Calls L/O. (of course, remember that you did that because ANY system you monitor will not play the voice calls after you do that unless you switch back to the Normal setting)
Mike
TheButcher
I get the same issue with 2.457 and TIII (standard). With 2.448, it doesn't scroll.
Does the DSD+ FL team need any raw audio recordings? I can contribute....
ps. I run 2 dongles. 1 for CC and the other for VC.
