DSD+FL Quit linking
DeaconHarry16
Beckley WV
Installed 2.324 on a different W10 PC from my first installation
Running RTL_SDR and FMP24 and R1
Worked fine after install but now getting this return on the event window
2021.07.02 22:41:16 Initiating FMPx link using link ID 20001...
2021.07.02 22:41:16 FMPx link established; link ID = 20001
2021.07.02 22:42:52 Server disconnected
2021.07.02 22:42:52 FMPx link lost
2021.07.02 22:42:52 Initiating FMPx link using link ID 20001...
2021.07.02 22:42:52 FMPx link error = -5
2021.07.02 22:42:52 [Server is not listening on selected link ID]
Everything loads OK and link query shows 20001 but now lost FMPx link
Any ideas?
slicerwizard
Toronto, Ontario
Sounds like you don't have a copy of FMPA/FMPP/FMP24 running and listening for traffic on link ID 20001. What does FMPx have to say?
DeaconHarry16
Beckley WV
C:\Users\Harry\Documents\Radio\DSD+>FMP24 -rc -i1 -o20001 -P0.0 -f854.9125 -b9.5
FMP24 2.74
Current working directory is "C:\Users\Harry\Documents\Radio\DSD+"
SDR sampling rate = 2.400 MHz
Spectrum window width: 1024
FFT size: 32,768
Spectrum update rate: 10 Hz
Step size table: 5.000 6.250 7.500 12.500 15.000 25.000 100.000
DSD+ path is "C:\Users\Harry\Documents\Radio\DSD+"
Primary frequency list: '.\FreqList.csv'
Secondary frequency list: '.\FreqList2.csv'
Database search distance: 99.90 miles
Base latitude/longitude: 19.7163 -155.6241
Role is control/rest channel monitor;
Auto-starting control/rest channel following mode
Using RTL SDR device #1
Using DSD+ link ID 20001
PPM correction set to 0.0
Initial frequency set to 854.912500 MHz
9.50 kHz RF bandpass filter selected
Optimizing FFT calculations... done.
Audio output device #1 = 'Speakers (Realtek High Definiti'
Audio output device #2 = 'CABLE Input (VB-Audio Virtual C'
SDR device count = 1
SDR device #1 serial string = '00000001'
Found Rafael Micro R820T tuner
Tuner type=5 (R820T)
Serial string = '00000001'
Sampling rate set to 2.400000 MHz
Frequency correction factor = 0.0 PPM
Waiting for DSD+ link with link ID 20001
No frequency data files found
Trunk control/rest channel following active
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
When they added the link ID feature I found that my DSD was expecting link ID but my FMPx was sending TCP port ID (despite me trying to use the link ID command line switches). I see you've provided the executable string for your FMP24 in the third post, what's your string for DSDplus?
DeaconHarry16
Beckley WV
Thank you for your replies. I am away from my SDR for a couple of days I’ll post when I get back in town. Thanks
DeaconHarry16
Beckley WV
On a hunch I thought the dsdplus .bin file might be the culprit...deleted it and bingo it took right off.
Program created a new .bin file. Not sure how it became corrupt but it works fine now.
Thanks for replies
Harry
