DSD FME
radioopperator
It errors out on me ?
This is what I'm trying to run only edited at bottom
@rem Digital Speech Decoder: Florida Man Edition
@rem DSD-FME Cygwin Windows Portable Builds
@rem
@rem The source code of this software can be downloaded here:
@rem GitHub - lwvmobile/dsd-fme: Digital Speech Decoder - Florida Man Edition
@rem
@rem If you paid for, or were otherwise fleeced for this software, DEMAND YOUR MONEY BACK!
@rem
@rem This software is designed to be used with an SDR receiver (like SDR++ or SDR#) with TCP input,
@rem RTL Input, media file playback over virtual cables or null-sinks, or a Discriminator Tap input
@rem
@rem The complete options list can be seen by viewing complete_usage_options.txt
@rem Many examples can be found in example_options.txt
@rem
@rem Enjoy!
@rem Regarding the options string (or any string in .bat files)
@rem If your string may contain spaces, set the first '"' before options, and then an ending '"'
@rem Incorrect: set options="-fs -N -Z"
@rem Correct: set "options=-fs -N -Z"
@rem set options to pass to dsd-fme
set "options= -N -Z "
@rem Set Date Time for log (sourced from: Format date and time in a Windows batch script)
@Echo off
REM "%date: =0%" replaces spaces with zeros
set d=%date: =0%
REM "set yyyy=%d:~-4%" pulls the last 4 characters
set yyyy=%d:~-4%
set mm=%d:~4,2%
set dd=%d:~7,2%
set dow=%d:~0,3%
set d=%yyyy%%mm%%dd%
set t=%TIME: =0%
REM "%t::=%" removes semi-colons
REM Instead of above, you could use "%t::=-%" to
REM replace semi-colons with hyphens (or any
REM non-special character)
set t=%t::=%
set t=%t:.=%
set datetimestr=%d%_%t%
@rem @Echo Long date time str = %datetimestr%
@rem random number is used so that two log files don't share the same name
set rnd=%RANDOM%
@rem set log file relative filepath
set "log=.\logs\log_%datetimestr%_%rnd%.txt"
@rem create the log file now with touch
.\dsd-fme\touch.exe %log%
@rem Launch Tail to display the log in a seperate console window
start .\dsd-fme\tail.exe -n 40 -f %log%
@rem start dsd-fme with options and log
@REM.\dsd-fme\dsd-fme.exe %options% 2> %log%
.\dsd-fme\dsd-fme.exe -ft -i rtl:1:770.61875M:0:32:12:0 -T -K multi_key_hex.csv -N -H -Z -c capture.bin 2> log.ans
echo ----------------------------------------------------------------------------------
echo For any errors, see: %log%
echo Forward %log% and Options: "%options%"
echo to developer on Github or Radio Reference for troubleshooting.
@rem Set pause to diplay above message
PAUSE
lwvmobile
DSD-FME
Lafayette County, FL
What command did you end up running, or what did you end up with in your bat file?
Not sure if you meant to or not, but this is in the forum, and not in the private messages, so not sure if you are replying to that conversation, or to something else here.
ki4hyf
Ridin' Dirty
Jackson, TN
Options are very important. Unlike Homer, computers can't read minds or dismiss input errors. You are missing the "-C" and it's corresponding channel map file. Also, there's a stray "-H" that shouldn't be there, otherwise it looks good. BTW, %XXX% is windows way of using variables in batch files.
