DSD+ Help
cmcclung
Houston, Texas
I have been able to get everything setup with two RTL-SDR dongles listening to the Fort Bend County TX P25 simulcast of TxWARN, however when I send the audio over to DSD+ via virtual audio cable all I end up hearing is garbled traffic. When data goes over to DSD+ it says
Sync: no sync
Sync:p25p1 NAC:1A3 TDU
Sync:p25p1 NAC:1A3 TDULC
Sync:p25p1 NAC:1A3 HDU
Sync: no sync
It will also give the lines
Sync:p25p1 NAC:1A3 LDU2 e:9rFr21Er3Er
Sync:p25p1 NAC:1A3 LDU1 e:DrCrCrCrCrCrCr
I haven't had any problems listening to the Fort Bend County TxWARN motorola simulcast, which I haven't even had to pass over to DSD+ to listen to.
Am I missing something here? I feel like I have read a lot on the software but haven't found anything that would suggest I missed a step. Thanks in advance for helping.
Forts
Mentor
Ontario, Canada
Why are you using VAC? FMP24 & DSD+ will communicate directly over TCP eliminating the need for virtual cables... Much nicer way to go.
This isn't a Phase II system is it? If so DSD+ doesn't do PII audio...
