DSDPlus 1.101
moonbounce
Just wondering, can you use DSDPlus 1.101 and FMP like you would with DSDPlus 1.74 and FMP in that the trunking is omitted. The reason I ask is that I tried Unitrunker but using the RTL dongles I couldn't get them to lock onto the control channel, so I never really got to use it. So if I am unable to lock on to the control channel would I be able to use DSD1.101 and FMP without the trunk feature.
MB
LimaZulu
MB
Yes you could use it anyway you like. Basically the biggest difference with the old version of DSD is trunking capability for wich you must run 2 instances, and edit dsdplus.frequencies file. Other than that it's all the same. Just pipe the audio wherever you need it.
