DSDPLUS dont display correct data in DMR
ronenp
Hi
When monitoring repeater input of DMR and the radio is on llot2 the software show slot1
and when monitoring the output the software show slot2
dsdplus 1.074
FYI
Ronen - 4Z4ZQ
Ronen Pinchooks (4Z4ZQ) WebSite
Forts
Mentor
Ontario, Canada
You will likely need to post a recording for them to investigate this. Hit R when DSDPlus is running and capture some voice activity, then upload it for analysis.
KevinC
32D2T/957.282
I'm everywhere Focker!
I seem to recall that would be correct. The subscriber will receive on TS 1 and transmit on TS 2 (or receive on 2 and transmit on 1)...but I could be wrong.
Forts
Mentor
Ontario, Canada
No... there shouldn't be any crossing of timeslots. What's on 1 stays on 1 no matter what.
KevinC
32D2T/957.282
Hmm...I sure thought the base station and subscribers used "inverted" timeslots...but as I said, I could be wrong.
DSDPlus
Incorrect. Recent Fast Lane builds do not display any slot number for simplex or repeater input traffic.
Edit: You even linked to a screen shot showing this...
racingfan360
Yes but the incorrect slot number still shows in the wav file information when per transmission recording is enabled. See post #10 of that thread. While displaying slot info has now been suppressed I assume the same underlying bug still exists in later builds. In comparison, DMRdecode decodes the slots correctly.
DSDPlus
No, just tested the same DSD+ 1.092pt that all FL members have and it created a file with the exact name 034253_008_DMR__DCC1_GC_302260_35001.wav
racingfan360
Ok, my bad. The slot number does now not show in the per sample recording wav file for 1.092pt, as you say. I hadn't seen any mention of that in the release notes. Thanks for the fix.
It looks like the problem was present in each of the earlier releases up to and including 1.090 - that would explain why ronenp was seeing the issue he describes.
Thanks again for all the continued development of DSDPlus.
